Robot Specific Blocks#
Introduction#
The V5RC 25-26 Push Back Playground features blocks exclusive to the build designed for this Playground, including two motor options, AI Vision Sensor, Optical Sensor, and Game Positioning System (GPS).
All standard VEXcode VR Blocks are available for use in the V5RC 25-26 Push Back Playground.
Below is a list of all available Playground-specific Blocks:
Motion – Move and track the robot’s motors.
Actions
spin – Spins the selected motor or motor group indefinitely.
spin for – Spins a motor or group for a specific distance in degrees or turns.
spin to position – Spins a motor or motor group to a set position.
stop motor – Stops a specific motor or motor group from spinning.
Settings
set motor velocity – Sets the speed of a motor or motor group as a percentage.
set motor timeout – Limits how long a motor block waits before giving up if movement is blocked.
Position
motor position – Returns the motor’s current rotational position in degrees or turns.
set motor position – Sets the encoder value of a motor or motor group.
Values
motor is done? – Returns a Boolean indicating whether the motor is no longer spinning.
motor is spinning? – Returns a Boolean indicating whether the motor is currently spinning.
motor velocity – Returns the motor’s current velocity in %.
AI Vision – Capture and analyze objects using the AI Vision Sensor.
Actions
get object data – Captures data for a specific object type, such as colors, pre-trained objects, or AprilTags.
Settings
set object item – Selects a specific object from the list.
Values
object exists? – Returns whether any classification was detected.
AI Classification is – Returns if a classification is detected.
object count – Returns how many objects were detected.
object property – Returns details such as:
Sensing – Utilize the robot’s various sensors.
Optical
Optical found object? – Returns whether an object is detected.
Optical detects color? – Returns whether a specific color is detected.
Optical brightness – Returns brightness in %.
Optical hue – Returns hue of the detected color.
when Optical – Executes attached blocks when the Optical Sensor detects or loses an object.
GPS
GPS position – Returns the X or Y position from the GPS Sensor.
GPS heading – Returns the heading the robot is currently facing.
The examples in this project use the default Playground start position.
Motion#
Actions#
spin#
The spin block spins a selected motor or motor group in a specified direction using the current motor velocity.
girar [ConveyorMotor v] [arriba v]
Parameters |
Description |
motor |
The motor group to spin:
direction |
The direction to spin:
Example
cuando empezó
[Pick up a second Block.]
girar [ConveyorMotor v] [arriba v] por [200] [grados v] ▶
girar [IntakeMotor v] [consumo v]
unidad [adelante v] para [350] [mm v] ▶
spin for#
The spin for block spins a selected motor or motor group for a specific amount of rotation using the current motor velocity, measured in degrees or turns.
girar [ConveyorMotor v] [arriba v] por (90) [grados v] ▶
Parameters |
Description |
motor |
direction |
distance |
The rotation amount, as an integer or decimal. |
unit |
The unit of measurement representing the distance:
expanding arrow |
By default, this is a waiting block, so the motor will finish moving before running the next block. To make the motor start moving and immediately run the next block right away, expand the block to say and don’t wait. |
Example
cuando empezó
spin to position#
The spin to position block spins a motor or motor group to a specific absolute position using the current motor velocity and motor position.
girar [ConveyorMotor v] a la posición (90) [grados v] ▶
Parameters |
Description |
motor |
position |
The target position to spin the motor group to. |
unit |
The unit of measurement:
expanding arrow |
Example
cuando empezó
girar [ConveyorMotor v] a la posición [200] [grados v] ▶
stop motor#
The stop motor block immediately stops the selected motor or motor group.
parada [ConveyorMotor v]
Parameters |
Description |
motor |
The motor group to stop:
Example
cuando empezó
parada [IntakeMotor v]
Settings#
set motor velocity#
The set motor velocity block sets the default spinning speed of a motor or motor group as a percentage for all subsequent Motor blocks in the project.
Establezca la velocidad [ConveyorMotor v] en [50] [% v]
Parameters |
Description |
motor |
The motor group to set the velocity of:
velocity |
Sets the default movement velocity from 0 to 100 as a percent. |
unit |
The unit that represents the velocity:
Example
cuando empezó
Establezca la velocidad [ConveyorMotor v] en [100] [% v]
unidad [adelante v] para [400] [mm v] ▶
set motor timeout#
The set motor timeout block sets a time limit for how long a Motor block will wait to reach its target. If the robot cannot complete the movement within the set time, it will stop automatically and continue with the next block.
Note: The Motor’s time limit is used to prevent Motor blocks that do not reach their target position from stopping the execution of other blocks in the stack.
Establezca el tiempo de espera [ConveyorMotor v] en [1] segundo
Parameters |
Description |
motor |
The motor group to set the timeout of:
time |
The maximum number of seconds a Motor block will run before stopping and moving to the next block. |
Example
cuando empezó
Establezca el tiempo de espera [ConveyorMotor v] en [0.5] segundo
girar [ConveyorMotor v] a la posición [1000] [grados v] ▶
Position#
motor position#
The motor position block returns the total distance the selected motor or motor group has rotated.
([ConveyorMotor v] posición en [grados v])
Parameters |
Description |
motor |
The motor group to return the position of:
unit |
Example
cuando empezó
mientras <([ConveyorMotor v] posición en [grados v]) [math_less_than v] [200]>
fin
set motor position#
The set motor position block sets a specific position value to a motor or motor group, which updates the encoder reading.
Establezca la posición [ConveyorMotor v] en (0) [grados v]
Parameters |
Description |
motor |
The motor group to set the position of:
position |
The encoder position value to set. |
unit |
Example
cuando empezó
Establezca la posición [ConveyorMotor v] en [-200] [grados v]
girar [ConveyorMotor v] a la posición [0] [grados v] ▶
Values#
motor is done#
The motor is done? block returns a Boolean indicating whether the motor or motor group is not spinning.
True – The motor is not spinning.
False – The motor is spinning.
<[ConveyorMotor v] ¿está hecho?>
Parameters |
Description |
motor |
The motor group to check if it isn’t spinning:
Example
cuando empezó
girar [ConveyorMotor v] a la posición [300] [grados v] ◀ y no esperes
unidad [adelante v]
esperar hasta <[ConveyorMotor v] ¿está hecho?>
deja de conducir
motor is spinning?#
The motor is spinning? block returns a Boolean indicating whether the motor is spinning.
True – The motor is spinning.
False – The motor is not spinning.
<[ConveyorMotor v] esta girando?>
Parameters |
Description |
motor |
The motor group to check if it is spinning:
Example
cuando empezó
esperar [0.1] segundos
mientras <[ConveyorMotor v] esta girando?>
unidad [adelante v] para [200] [mm v] ▶
motor velocity#
The motor velocity block returns the current rotational speed of the motor or motor group in a range from -100% to 100%.
([ConveyorMotor v] velocidad en [% v] :: custom-motion)
Parameters |
Description |
motor |
The motor group to return the velocity of:
unit |
Example
cuando empezó
esperar [0.2] segundos
imprimir ([ConveyorMotor v] velocidad en [% v] :: custom-motion) ▶
AI Vision#
Actions#
get object data#
The get object data block filters data from the AI Vision Sensor frame. The AI Vision Sensor can detect Game Elements on the field.
The dataset stores objects ordered from largest to smallest by width, starting at index 0. Each object’s properties can be accessed using AI Vision object property block. An empty dataset is returned if no matching objects are detected.
obtener [AI Classifications v] datos de AI Vision
Parameter |
Description |
signature |
Filters the dataset to only include data of the given signature. The only available signature is:
Example
cuando empezó
[If an object is detected, pick it up.]
para siempre
obtener [AI Classifications v] datos de [AIVision v]
si <¿Existe [AIVision v] objeto?> entonces
unidad [adelante v]
esperar hasta <[Bumper v] presionado?>
deja de conducir
romper
Settings#
set object item#
The set object item block sets which item in the dataset to use.
Establecer el elemento de objeto [AIVision v] en [1]
Parameters |
Description |
item |
The number of the item in the dataset to use. |
Example
cuando empezó
[Display what object is farthest away.]
para siempre
Establecer el elemento de objeto [AIVision v] en ([AIVision v] recuento de objetos)
borrar todas las filas
si <[AIVision v] object is [BlueBlock v]?> entonces
imprimir [Blue Block farthest away.] ▶
demás
imprimir [Red Block farthest away.] ▶
Values#
object exists?#
The object exists? block returns a Boolean indicating whether any object is detected in the dataset.
True – The dataset includes a detected object.
False – The dataset does not include any detected objects.
<¿Existe el objeto AI Vision?>
Parameters |
Description |
This block has no parameters. |
Example
cuando empezó
[If an an object is detected, pick it up.]
para siempre
unidad [adelante v]
deja de conducir
romper
AI Classification is#
The AI Vision object is? block returns a Boolean indicating whether a detected object matches a specific classification.
True – The item in the dataset is the specific object.
False – The item in the dataset is not the specific object.
<[AIVision] object is [BlueBlock v]?>
Parameter |
Description |
object |
Which object to compare the item to:
Example
cuando empezó
para siempre
demás
object count#
The object count block returns the number of detected objects in the dataset as an integer.
([AIVision] recuento de objetos)
Parameters |
Description |
Example
cuando empezó
para siempre
demás
object property#
There are six properties that are included with each object (shown below) stored after the get object data block is used.
([AIVision v] objeto [amplitud v])
Some property values are based off of the detected object’s position in the AI Vision Sensor’s view at the time that the get object data block was used. The AI Vision Sensor has a resolution of 320 by 240 pixels.
Parameter |
Description |
property |
Which property of the detected object to use: |
width#
width returns the width of the detected object in pixels as an integer from 1 to 320.
Example
cuando empezó
[If an an object is detected, approach and pick it up.]
para siempre
si <([AIVision v] objeto [amplitud v]) [math_greater_than v] [65]> entonces
deja de conducir
romper
demás
unidad [adelante v]
height#
height returns the height of the detected object in pixels as an integer from 1 to 240.
([AIVision v] objeto [altura v])
Example
cuando empezó
para siempre
si <([AIVision v] objeto [altura v]) [math_greater_than v] [55]> entonces
deja de conducir
romper
demás
unidad [adelante v]
centerX#
centerX returns the x-coordinate of the center of the detected object in pixels as an integer from 0 to 320.
([AIVision v] objeto [centroX v])
Example
cuando empezó
[Pick up a Block from the top left group.]
girar [izquierda v] por [80] grado ▶
unidad [adelante v] para [100] [mm v] ▶
establecer la velocidad de giro a [20] [% v]
turno [izquierda v]
para siempre
si <<[140] [math_less_than v] ([AIVision v] objeto [centroX v])> y <([AIVision v] objeto [centroX v]) [math_less_than v] [180]>> entonces
unidad [adelante v]
deja de conducir
centerY#
centerY returns the y-coordinate of the center of the detected object in pixels as an integer from 0 to 240.
([AIVision v] objeto [centroY v])
Example
cuando empezó
para siempre
si <([AIVision v] objeto [centroY v]) [math_greater_than v] [140]> entonces
deja de conducir
romper
demás
unidad [adelante v]
originX#
originX returns the x-coordinate of the top-left corner of the detected object’s bounding box in pixels as an integer from 0 to 320.
([AIVision v] objeto [origenX v])
Example
cuando empezó
turno [izquierda v]
para siempre
si <<[100] [math_less_than v] ([AIVision v] objeto [origenX v])> y <([AIVision v] objeto [origenX v]) [math_less_than v] [140]>> entonces
unidad [adelante v]
deja de conducir
originY#
originY returns the y-coordinate of the top-left corner of the detected object’s bounding box in pixels as an integer from 0 to 240.
([AIVision v] objeto [origenY v])
Example
cuando empezó
para siempre
si <[120] [math_less_than v] ([AIVision v] objeto [origenY v])> entonces
deja de conducir
romper
demás
unidad [adelante v]
fin
fin
Sensing#
Optical#
Optical found object?#
The Optical found object? block returns a Boolean indicating whether the Optical Sensor has detected an object.
True – The Optical Sensor has detected an object.
False – The Optical Sensor has not detected an object.
<[Optical v] Encontraste un objeto?>
Parameters |
Description |
Example
cuando empezó
[Move the preloaded Block to the top of the Conveyor.]
esperar hasta <[Optical v] Encontraste un objeto?>
Optical detects color?#
The Optical detects color? block returns a Boolean indicating whether the Optical Sensor has detected a specific color.
True – The Optical Sensor has detected the specified color.
False – The Optical Sensor has not detected the specified color.
<[Optical v] detecta [rojo v]?>
Parameters |
Description |
color |
Which color to check for:
Example
cuando empezó
[Pick up and move a Blue Block to the top of the Conveyor.]
unidad [adelante v] para [360] [mm v] ▶
esperar hasta <[Optical v] detecta [azul v]?>
Optical brightness#
The Optical brightness block returns the amount of light detected by the Optical Sensor in a range from 0% to 100%.
([Optical v] brillo en %)
Parameters |
Description |
Example
cuando empezó
esperar hasta <[0] [math_less_than v] ([Optical v] brillo en %)>
Optical hue#
The Optical hue block returns the hue value of the color detected by the Optical Sensor.
Hue values range from 0 to 359 degrees, corresponding to positions on the color wheel shown below.
([Optical v] tono en grados)
Parameters |
Description |
Example
cuando empezó
esperar hasta <[240] [math_equal v] ([Optical v] tono en grados)>
when Optical#
The when Optical block runs its stack when the Optical Sensor detects or loses an object. You can have multiple when Optical blocks to run multiple stacks of blocks at once.
cuando [Optical v] [detects v] un objeto
Parameters |
Description |
action |
Which action to trigger the hat block:
Example
Example coming soon!
GPS#
GPS position#
The GPS position block returns the positional offset of the robot’s turning reference point from the center of a field with the GPS (Game Positioning System™) Sensor.
([GPS v] posición [X v] en [mm v])
Parameters |
Description |
axis |
Which acis to report:
units |
The unit to represent the position:
Example
cuando empezó
unidad [adelante v]
esperar hasta <[-450] [math_greater_than v] ([GPS v] posición [Y v] en [mm v])>
deja de conducir
GPS heading#
The GPS heading block returns the heading that the robot is currently facing based on the GPS (Game Positioning System™) Sensor’s readings from the VEX GPS Field Code from 0.00 to 359.99 degrees.
([GPS v] rumbo en grados)
Parameters |
Description |
Example
cuando empezó
[Score the preloaded Block into a Center Goal.]
turno [izquierda v]
esperar hasta <[40] [math_greater_than v] ([GPS v] rumbo en grados)>
unidad [adelante v] para [1000] [mm v] ▶
turno [derecha v]
esperar hasta <([GPS v] rumbo en grados) [math_greater_than v] [310]>
unidad [atrás v] para [200] [mm v] ▶
