Robot Specific Blocks#
All standard VEXcode VR Blocks are available for use in the V5RC Virtual Skills - Over Under Playground.
Motion#
This Playground’s Blocks will have access to the IntakeMotorGroup and ArmMotorGroup parameters for all Motion blocks.
When selecting a direction for Motion blocks, intake will spin the motor group forward and outtake spins the motor group in reverse.
Spin#
The Spin block is used to spin a motor indefinitely.
This is a non-waiting block and allows any subsequent blocks to execute without delay.
girar [IntakeMotorGroup v] [consumo v]
Select which motor to use.
Diagram of a spin motor block used in VEXcode VR for robot motion control and motor manipulation.
Select which direction for the motor to move in.
spin_direction
In this example, the intake motors will spin in the intake direction for 1 second before stopping.
cuando empezó
esperar (1) segundos
parada [IntakeMotorGroup v]
Spin for#
The Spin for block is used to spin a motor for a given distance.
This is can be a non-waiting or waiting block depending on if the and don’t wait option is used.
girar [IntakeMotorGroup v] [consumo v] por [90] [grados v] ▶
Diagram illustrating the Spin for block in VEXcode VR for controlling motor movement.
spin_for_direction
Set how far the motor will spin by entering a value, and choosing the unit of measurement (degrees or turns).
spin_for_unit
By default, the Spin for block will block any subsequent blocks from executing until it’s finished. By expanding the Spin for block to show and don’t wait, blocks will continue to execute while the motor is moving.
girar [IntakeMotorGroup v] [consumo v] por [90] [grados v] ◀ y no esperes
In this example, the intake motors will spin in the intake direction for 1 turn.
cuando empezó
girar [IntakeMotorGroup v] [consumo v] por [1] [giros v] ▶
Spin to position#
The Spin to position block is used to spin a motor to a set position.
girar [IntakeMotorGroup v] a la posición [90] [grados v] ▶
Diagram of VEXcode VR Spin to Position motor block for controlling motor movement in robotics programming.
spin_to_position_unit
By default, the Spin to position block will block any subsequent blocks from executing until it’s finished. By expanding the Spin to position block to show and don’t wait, blocks will continue to execute while the motor is moving.
girar [IntakeMotorGroup v] a la posición [90] [grados v] ◀ y no esperes
In this example, the motor will spin to the 270 degrees position.
cuando empezó
girar [IntakeMotorGroup v] a la posición [270] [grados v] ▶
Stop Motor#
The Stop Motor block is used to stop the motor from moving.
Icon representing the 'Stop Motor' block in VEXcode VR, used to halt motor movement in robot programming.
cuando empezó
Set Motor position#
The Set Motor position block is used to set a motor’s encoder position(s) to the entered value.
Establezca la posición [IntakeMotorGroup v] en [0] [grados v]
Diagram illustrating VEXcode VR motion blocks for controlling motor position, velocity, and sensing in robotics.
Set the unit of measurement to use, degrees or turns.
set_motor_position_unit
In this example, the Motor’s encoder position is set to 90 degrees before the motor spins to the 0 degrees position.
cuando empezó
Establezca la posición [IntakeMotorGroup v] en [90] [grados v]
girar [IntakeMotorGroup v] a la posición [0] [grados v] ▶
Set Motor velocity#
The Set Motor velocity block is used to set the speed of a motor.
Establezca la velocidad [IntakeMotorGroup v] en [50] [% v]
Diagram illustrating VEXcode VR Motion blocks for controlling motor velocity and position in robotics.
The Set Motor velocity block will accept a range of -100% to 100%.
In this example, the Motor’s velocity is set to 75% before it spins for 1 turn in the intake direction.
cuando empezó
Establezca la velocidad [IntakeMotorGroup v] en [75] [% v]
Set Motor timeout#
The Set Motor timeout block is used to set a time limit for Motor movement blocks.
This prevents motion blocks that do not reach their intended position from preventing subsequent blocks from running.
This is a non-waiting command and allows any subsequent commands to execute without delay.
Establezca el tiempo de espera [IntakeMotorGroup v] en [1] segundo
Diagram illustrating the Set Motor Timeout block for controlling motor movement duration in VEXcode VR.
In this example, the motor timeout is set to 2 seconds before it spins the motor for 3 turns in the outtake direction.
cuando empezó
Establezca el tiempo de espera [IntakeMotorGroup v] en [2] segundo
girar [IntakeMotorGroup v] [descartar v] por [3] [giros v] ▶
Sensing#
Striker has access to the standard Brain, Drivetrain, Bumper, Distance Sensing Blocks.
Eye Sensing has been renamed to Optical Sensing to match the Front Optical Sensor.
Motor Sensing#
Motor is done#
The Motor is done block is used to report if the selected Motor or Motor Group has completed its movement.
<[IntakeMotorGroup v] ¿está hecho?>
Select which Motor or Motor Group to use.
Robot motion blocks for VEXcode VR, including Spin, Stop Motor, and Sensing Motor functionalities.
The Motor is done block reports True when the selected Motor or Motor Group has completed its movement.
The Motor is done block reports False when the selected Motor or Motor Group has not completed its movement.
The Motor is done block is used in blocks with hexagonal (six-sided) spaces.
In this example, the Arm will be raised so the Distance Sensor can report the closest object’s distance.
cuando empezó
[Raise the Arm out of the way of the Front Distance Sensor.]
girar [ArmMotorGroup v] a la posición [1000] [grados v] ◀ y no esperes
[Wait until the Arm has finished moving.]
esperar hasta <[ArmMotorGroup v] ¿está hecho?>
[Print the distance between the Front Distance Sensor and the closest object in front of it.]
imprimir ([FrontDistance v] distancia del objeto en [mm v]) ▶
Motor is spinning#
The Motor is spinning block is used to report if the selected Motor or Motor Group is moving.
<[IntakeMotorGroup v] esta girando?>
Image of a spinning motor block used in VEXcode VR for robot motion control and programming.
The Motor is spinning block reports True when the selected Motor or Motor Group is moving.
The Motor is spinning block reports False when the selected Motor or Motor Group is not moving.
The Motor is spinning block is used in blocks with hexagonal (six-sided) spaces.
In this example, the Arm will be raised while the Intake Motor Group is still moving.
cuando empezó
[Take a Block into the Intake.]
[Execute Blocks while the Intake Motor Group is still moving.]
mientras <[IntakeMotorGroup v] esta girando?>
[Move the Arm to a position of 1000 degrees.]
fin
Position of motor#
The Position of motor block is used to report the position of a Motor or the first motor in a Motor Group.
([IntakeMotorGroup v] posición en [grados v])
Select when unit to use, degrees or turns.
motor_position_unit
The Position of motor block is used in blocks with circular spaces.
In this example, the robot will print the current position of the Arm Motor Group.
cuando empezó
imprimir ([ArmMotorGroup v] posición en [grados v]) ▶
Velocity of motor#
The Velocity of motor block is used to report the current velocity of a Motor or the first motor in a Motor Group.
([IntakeMotorGroup v] velocidad en [% v] :: custom-motion)
The Velocity of motor block is used in blocks with circular spaces.
In this example, the robot will print the current velocity of the Intake Motor Group.
cuando empezó
imprimir ([IntakeMotorGroup v] velocidad en [% v] :: custom-motion) ▶
GPS Sensing#
GPS position#
The GPS position block is used to report the positional offset of the robot’s turning reference point from the center of a field.
([GPS v] posición [X v] en [mm v])
Select either the X or Y axis offset of the robot’s turning reference point from the center of the field to report.
Diagram illustrating GPS position and axis reference for robot navigation in VEXcode VR.
Select what unit to report the offset value in, millimeters (MM) or inches.
Image of a GPS position unit used in VEXcode VR for robot motion and navigation tasks.
The GPS position block is used in blocks with circular spaces.
In this example, the robot will print the current Y offset of the robot’s turning reference point
cuando empezó
imprimir ([GPS v] posición [Y v] en [mm v]) ▶
GPS heading#
The GPS heading block is used to report the heading that a robot is currently facing based on a GPS Sensor’s readings from the VEX GPS Field Code.
GPS heading reports a range from 0.00 to 359.99 degrees.
([GPS v] rumbo en grados)
The GPS heading block is used in blocks with circular spaces.
In this example, the robot will print the current GPS heading.
cuando empezó
imprimir ([GPS v] rumbo en grados) ▶
