Device Setup: Controller#
Add a Controller#
Open the Devices Tab#
Select the Devices tab.
If the Devices tab is not visible, see Add a Tab in the Navigating VEXcode tutorial.
Select Add a Device#
Select Add a Device in the Devices tab.
Select Controller#
Select Controller from the devices menu.
Set Controller Actions#
The Controller’s buttons and joysticks are shown, labeled by name. If you have a Drivetrain and/or Motor configured, you can assign controls for them here. These configured actions only run during a project while the Controller enable/disable block has them enabled.
Left Arcade#
The left joystick controls both the Drivetrain’s forward and reverse movement and its turning.
Right Arcade#
The right joystick controls both the Drivetrain’s forward and reverse movement and its turning.
Split Arcade#
The left joystick’s up and down controls the Drivetrain’s forward and reverse movement, while the right joystick’s left and right controls turning.
Tank Drive#
The left joystick’s up and down controls the left side of the Drivetrain, and the right joystick’s up and down controls the right side, independently.
Finish Adding the Controller#
Select Done to add the controller to your robot.
View the Controller in Your Devices List#
The controller will now appear in your list of devices, and the Controller category and blocks will be added to your toolbox.
