Field Details#
The VIQRC Virtual Skills - Rapid Relay Playground occupies an area measuring 1800 millimeters (about 6 feet) long and 2400 millimeters (about 8 feet) wide.
The field is 5 full black squares and two half-squares long and 7 full black squares and two half-squares wide.
Grid |
Measurement |
A full black square measures 300mm by 300mm (approximately 12 inches by 12 inches). |
A half black square measures 150mm by 300 mm (approximately 6 inches by 12 inches). |
Game Elements#
The Field has one Game Element, Balls.
Game Element |
Measurements |
Amount on Field |
A yellow padded, roughly spherical object, with a diameter of approximately 5.9” (150mm) and a weight of approximately 4.2 ounces |
2 |
Field Starting Configurations#
There are 2 total starting positions you can choose to start your robot from, labeled A and B. By default, the robot starts on position B.
There are 4 total starting directions you can choose to face your robot in when it starts, North, East, South, and West. By default, the robot starts facing North.
You can set the position of the second, unloaded Ball on the field. There are four possible positions for this Ball, labeled 1 through 4. By default, the Ball is placed in position 3.
