Field Details#
The VIQRC Virtual Skills - Full Volume Playground occupies an area measuring 1800 millimeters (about 6 feet) long and 2400 millimeters (about 8 feet) wide.
The field is 5 full black squares and two half-squares long and 7 full black squares and two half-squares wide.
Grid |
Measurement |
A full black square measures 300mm by 300mm (approximately 12 inches by 12 inches). |
A half black square measures 150mm by 300 mm (approximately 6 inches by 12 inches). |
Game Elements#
The Field has three different Game Elements, Green Blocks, Purple Blocks, and Red Blocks.
There are fifty-four (54) Green Blocks.
Game Element |
Measurements |
Amount on Field |
A six-sided block measuring approximately 51mm or 2 inches per side. |
54 |
A six-sided block measuring approximately 76mm or 3 inches per side. |
16 |
A partially-rounded octagonal shape that has a major diameter of approximately 147 mm or 5.8 inches. |
3 |
Field Starting Configurations#
There are 5 total starting positions you can choose to start your robot from, labeled A through E. By default, the robot starts on position A.
