Field Details#
The V5RC Virtual Skills - Over Under Playground occupies an area measuring 3.65 meters (about 12 feet) long and 3.65 meters (about 12 feet) wide.
The field is 6 full tiles long and 6 full tiles wide.
Grid |
Measurement |
Each tile on the Field measures 600 mm by 600 mm. |
Game Elements#
The Field has one Game Element, Triballs.
Game Element |
Measurements |
Amount on Field |
A green, red, or blue plastic scoring object with a slightly rounded triangular pyramidal shape known as a Reuleaux triangle. Each Triball is approximately 6.18” tall with a weight of 103-138g. |
60 - 4 Alliance, 12 on the Field, 44 Match Loads |
Field Starting Configurations#
The V5RC Virtual Skills - Over Under Playground has access to a Pre-Match checklist to customize your robot’s starting conditions before running your code.
There are 8 total starting locations you can choose to start your robot from, labeled A through H. By default, the robot starts on position E.
There are 4 total starting directions you can choose to face your robot in when it starts, North, East, South, and West.
You can also choose whether or not you want to preload your robot with an alliance triball or not.
Finally, you can set your second alliance triball’s position on the field from 1 to 10.
