Field Details#
The V5RC Virtual Skills - Tipping Point Playground occupies an area measuring 3.65 meters (about 12 feet) long and 3.65 meters (about 12 feet) wide.
The field is 6 full tiles long and 6 full tiles wide.
Grid |
Measurement |
Each tile on the Field measures 600 mm by 600 mm. |
Game Elements#
The Field has one Game Element, Triballs.
Game Element |
Measurements |
Amount on Field |
Rings have a maximal outer diameter of 4.125” (104.8mm) and a minimal inner diameter of 2” (50.8mm) |
72 |
Field Starting Configurations#
The V5RC Virtual Skills - Tipping Point Playground has access to a starting configuration window to customize your robot’s starting conditions before running your code.
There are 4 total starting locations you can choose to start your robot from, labeled A through D. By default, the robot starts on position B.
There are 4 total starting angles you can choose for your robot, so you can start facing a desired target.
You can also choose whether or not you want to preload your robot with any rings or not. Remember that you can only preload 2 rings on one side of your robot.
