Field Details#
The V5RC Virtual Skills - High Stakes Playground occupies an area measuring 3.65 meters (about 12 feet) long and 3.65 meters (about 12 feet) wide.
The field is 6 full tiles long and 6 full tiles wide.
Grid |
Measurement |
Each tile on the Field measures 600 mm by 600 mm. |
Game Elements#
The Field has three Game Elements, Red Rings, Blue Rings, and Mobile Goals.
Game Element |
Measurements |
Amount on Field |
A hollow red torus-shaped plastic object with an outer diameter of 7” (177.8 mm), an inner “hole” diameter of 3” (76.2 mm), and a thickness (or “tube diameter”) of 2” (50.8 mm). |
24 |
A hollow blue torus-shaped plastic object with an outer diameter of 7” (177.8 mm), an inner “hole” diameter of 3” (76.2 mm), and a thickness (or “tube diameter”) of 2” (50.8 mm). |
10 |
Hexagonal scoring objects with a maximal diameter of 10” (254 mm) and an overall height of 14.5” (368.3 mm). |
5 |
Field Starting Configurations#
The V5RC Virtual Skills - High Stakes Playground has access to a Pre-Match checklist to customize your robot’s starting conditions before running your code.
There are 4 total starting locations you can choose to start your robot from, labeled A through D. By default, the robot starts on position C.
There are also 3 total starting directions you can choose to face your robot in when it starts, North, East, and South. By default, the robot starts facing East.
