机器人专用 Python#
所有标准 VEXcode VR 命令均可在VIQRC 虚拟技能 - 快速接力游乐场中使用。
运动#
motor.spin()#
The motor.spin(direction) command is used to spin a motor indefinitely.
这是一个非等待命令,允许任何后续命令无延迟地执行。
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.spin(direction).
对象
描述
intake_motor
旋转 Swish 的进气口来收集球并将它们放在弹射器上。
catapult_group
升高或降低 Swish 的弹射器来发射球。
参数
描述
direction
The direction for the motor to move in: FORWARD or REVERSE.
**返回:**无。
# Spin the Intake Motor to bring a Ball onto the Catapult.
intake_motor.spin(FORWARD)
wait(2, SECONDS)
intake_motor.stop
motor.spin_for()#
The motor.spin_for(direction, distance, units, wait) command is used to spin a motor for a given amount of degrees or turns.
This is can be a non-waiting or waiting command depending on if the wait parameter is used.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.spin_for(direction, distance, units, wait).
对象
描述
intake_motor
catapult_group
参数
描述
direction
distance
电机移动的距离,为整数。
units
The units that the motor will use: DEGREES or TURNS.
wait
Optional. The wait parameter determines whether the command will block subsequent commands (wait=True) or allow immediate execution (wait=False). If unspecified, the default for the wait parameter is wait=True.
**返回:**无。
# Launch the Ball currently loaded on the Catapult.
catapult_group.spin_for(REVERSE, 5, DEGREES)
# Lower the Catapult to prepare to load another Ball.
catapult_group.spin_for(FORWARD, 1350, DEGREES)
motor.spin_to_position()#
The motor.spin_to(angle, units, wait) command is used to spin a motor to a given position.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.spin_for(angle, units, wait).
对象
描述
intake_motor
catapult_group
参数
描述
angle
电机旋转的特定角度或圈数。
units
wait
**返回:**无。
catapult_group.spin_to_position(-90, DEGREES)
catapult_group.spin_to_position(1260, DEGREES)
motor.stop()#
The motor.stop() command is used to stop a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.stop().
对象
描述
intake_motor
catapult_group
**返回:**无。
wait(2, SECONDS)
intake_motor.stop
motor.set_position()#
The motor.set_position(position, units) command is used to set a motor’s encoder position to the given position value.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.set_position(position, units).
对象
描述
intake_motor
catapult_group
参数
描述
position
要设置的电机编码器的具体整数。
units
The units for the motor to use: DEGREES or TURNS.
**返回:**无。
# Set the new Catapult position to be 0 degrees.
catapult_group.set_position(0, DEGREES)
motor.set_velocity()#
The motor.set_velocity(velocity, units) command is used to set the speed of a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.set_velocity(velocity, units).
对象
描述
intake_motor
catapult_group
参数
描述
velocity
电机旋转的速度,范围从 -100 到 100。
units
The unit for the Motor’s velocity, PERCENT.
**返回:**无。
# Start spinning the Intake Motor to prepare
# for picking up a Ball.
intake_motor.set_velocity(100, PERCENT)
motor.set_timeout()#
The motor.set_timeout(value, units) command is used to set a time limit for a motor’s movement commands.
这可以防止未到达预定位置的运动命令阻止后续命令运行。
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.set_timeout(value, units).
对象
描述
intake_motor
catapult_group
参数
描述
value
电机停止前等待的时间。
units
The unit for the Motor’s timer, SECONDS.
**返回:**无。
catapult_group.set_timeout(2, SECONDS)
catapult_group.spin_for(6, TURNS)
活动#
intake_optical.object_detected()#
intake_optical.object_detected(callback) is the same command as eye.object_detected(callback).
The command only uses Swish’s Optical Sensor intake_optical to replace eye in the standard command.
For information on how to use the eye.object_detected(callback) command, go to its API documentation here.
intake_optical.object_lost()#
intake_optical.object_lost(callback) is the same command as eye.object_lost(callback).
For information on how to use the eye.object_lost(callback) command, go to its API documentation here.
传感#
motor.is_done()#
The motor.is_done() command is used to return a True or False value if the selected motor has completed its movement.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.is_done().
对象
描述
intake_motor
catapult_group
**返回:**这将返回一个布尔值。
motor.is_spinning()#
The motor.is_spinning() command is used to return a True or False value if the selected motor is moving.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.is_spinning().
对象
描述
intake_motor
catapult_group
**返回:**这将返回一个布尔值。
motor.position()#
The motor.position(units) command is used to return the current rotational position of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.position(units).
对象
描述
intake_motor
catapult_group
参数
描述
units
The unit of the returned value, DEGREES or TURNS.
**返回:**这将返回一个数值。
while not catapult_group.position(DEGREES) == 1260:
    catapult_group.spin(FORWARD)
motor.velocity()#
The motor.velocity(units) command is used to return the current velocity of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.velocity(units).
对象
描述
intake_motor
catapult_group
参数
描述
units
The unit of the motor’s velocity, PERCENT.
**返回:**这将返回一个数值。
brain.screen.print(catapult_group.velocity(PERCENT))
intake_optical.is_near_object()#
The intake_optical.near_object() command is used to report a Boolean value if the Optical Sensor is close enough to a Ball to detect it.
**返回:**报告一个布尔值。
# Launch a loaded Ball once the Intake Optical Sensor
# detects a Ball in the Intake.
if intake_optical.is_near_object():
intake_optical.color()#
The intake_optical.color() command is used to return the color detected by the Intake Optical Sensor.
以下颜色可用于与检测到的颜色进行比较:
  • RED
  • GREEN
  • BLUE
  • YELLOW
  • ORANGE
  • PURPLE
  • CYAN
**返回:**以字符串形式返回检测到的颜色的名称。
if intake_optical.color() == YELLOW:
intake_optical.brightness()#
The intake_optical.brightness() command is used to report the amount of light detected by an Optical Sensor within a range of 0 to 100 percent.
**返回:**这将返回一个数值。
if intake_optical.brightness() > 0:
intake_optical.hue()#
The intake_optical.brightness() command is used to report the hue of the object detected by an Optical Sensor within a range of 0 to 359. This number represents the location of the detected color on a color wheel.
**返回:**这将返回一个数值。
if intake_optical.hue() > 100:
