Optical Sensor#
Introduction#
The Optical Sensor detects the color, brightness, and presence of nearby objects using a combination of an RGB color sensor and proximity sensor. It can also use its built-in LED to illuminate objects for more accurate detection.
The VEX Optical Sensor.
Below is a list of available blocks:
set Optical light#
The set Optical light stack block turns the Optical Sensor’s LED on or off. This can help increase the sensor’s accuracy when detecting colors.
  set [Optical1 v] light [on v]
Parameters
Description
device
Which Optical Sensor to use, configured in the Devices window.
state
The state of the Optical Sensor’s light: on or off.
  when started
  [Turn on the sensor's LED.]
set Optical light power#
The set Optical light power stack block sets the brightness of the Optical Sensor’s LED. The light can help the Optical Sensor detect objects and colors more clearly.
A higher percentage makes the light brighter. A lower percentage makes the light dimmer.
If the Optical Sensor’s light is off, setting the light power above 0% will turn the light on.
If the Optical Sensor’s light is on, setting the light power at 0% will turn the light off.
  set [Optical1 v] light power to [50] %
Parameters
Description
device
brightness
The brightness to set the Optical Sensor’s light to, from 0% to 100%. Use whole numbers.
  when started
  [Turn on the sensor's LED at half brightness.]
Optical found an object#
The Optical found an object Boolean block reports whether or not the Optical Sensor detects an object within range.
  • True — The Optical Sensor detects an object.
  • False — The Optical Sensor does not detect an object.
  <[Optical1 v] found an object?>
Parameters
Description
device
Example
Drive forward until an object is detected#
  when started
  [Drive forward until an object is found.]
  drive [forward v]
  wait until <[Optical1 v] found an object?>
  stop driving
Optical detects color#
The Optical detects color Boolean block reports whether the Optical Sensor detects a specified color, based on the detected hue value.
  • True – The sensor detects the specified color.
  • False – The sensor does not detect the specified color.
Note: The Optical Sensor is looking for hue ranges that match the specified color. For detecting specific hue ranges, see the Optical hue reporter block.
  <[Optical1 v] detects [red v]?>
Parameters
Description
device
color
Which color to look for:
  • red – A detected hue value between 340° - 20°.
  • green – A detected hue value between 80° - 140°.
  • blue – A detected hue value between 200° - 240°.
  • yellow – A detected hue value between 40° - 60°.
  • orange – A detected hue value between 20° - 40°.
  • purple – A detected hue value between 240° - 280°.
  • cyan – A detected hue value between 140° - 200°.
Example
Drive forward until red is detected#
  when started
  [Drive forward until red is found.]
  drive [forward v]
  wait until <[Optical1 v] detects [red v]?>
  stop driving
Optical brightness#
The Optical brightness reporter block reports how much light is reflected back to the Optical Sensor, as a percentage from 0% to 100%.
A higher percentage means more light is reflected back to the Optical Sensor. A lower percentage means less light is reflected back.
  ([Optical1 v] brightness in %)
Parameters
Description
device
Optical hue#
The Optical hue reporter block reports the hue detected by the Optical Sensor as a number from 0 to 359 degrees.
Hue is a way to describe color using numbers around a color wheel.
The VEX Color Wheel showing the degrees of colors around a circle, with red at 0 degrees and transitioning through the rainbow as the value increases.
  ([Optical1 v] hue in degrees)
Parameters
Description
device
Example
  when started
  [Look for the color pink using hue.]
  forever
  clear screen
  set cursor to row [1] column [1] on screen
  if <[300] [math_less_than v] ([Optical1 v] hue in degrees) [math_less_than v] [359]> then
    print [This is pink!] on screen ▶
  else
  print [No pink detected!] on screen ▶
when Optical#
The when Optical hat block runs the attached stack of blocks whenever the Optical Sensor detects or loses an object.
  when [Optical1 v] [detects v] an object :: hat events
Parameters
Description
device
state
When the attached stack of blocks will run: detects runs when an undetected object is detected, while loses runs when a detected object is now no longer detected.
