Configuring Devices#
Configuring Devices
This tutorial walks you through configuring a device in VEXcode IQ (2nd gen), using a Touch LED as an example. By the end, you’ll have added a Touch LED and be ready to use its blocks.
Select the Devices tab.
Select Add a Device.
Select Touch LED.
Select which port the Touch LED is connected to on the Brain.
Select Done to add it to your robot.
The Touch LED will now appear in your list of Devices.
The Touch LED’s blocks will now appear in the toolbox, within the Sensing category.
