If Then Blocks#
If Then Blocks
This tutorial covers how to use if/else blocks to make your robot check a condition and decide which blocks to run. By the end, you’ll know how to set up a condition and control what happens when it’s true or false.
Drag a Boolean block into the empty condition slot in the if then branch.
A controller button R up pressed Boolean block being dragged into the empty condition slot of an if/else block.
All Boolean blocks are hexagon-shaped and have a question mark in their name, such as the controller button pressed? block.
An if/else block with a controller button R up pressed Boolean block, with the Boolean block highlighted.
If the condition is true, the blocks inside the if then branch will run.
An if/else block with a controller button R up pressed Boolean block and a drive forward block, with the drive forward block highlighted.
If the condition is false, the blocks inside the else branch will run.
An if/else block with a controller button R up pressed Boolean block, a drive forward block, and a stop driving block, with the stop driving block highlighted.
An if/else block only checks its condition once. If you want the condition to be checked repeatedly, put the if/else block inside a looping block, like forever.
An if/else block nested inside a forever block.#
    forever
        if <Controller [R ▲ v] pressed?> then
            drive [forward v]
        else
            stop driving
        end
    end
The if block is only the if then branch. If the condition isn’t true, nothing will happen.
The if block.#
        drive [forward v]
    end
The if / else if / else block can be used to test multiple conditions one after another. It can be expanded to test as many conditions as needed.
An if/else if/else block, testing all three Brain buttons.#
    if <Brain [◀ v] button pressed?> then
        turn [left v] for (90) degrees ▶
    else if <Brain [▶ v] button pressed?> then
        turn [right v] for (90) degrees ▶
    else if <Brain [Check v] button pressed?> then
        stop driving
    else
        drive [forward v]
    end
