Robot Specific Blocks#
Introduction#
The V5RC 25-26 Push Back Playground features blocks exclusive to the build designed for this Playground, including two motor options, AI Vision Sensor, Optical Sensor, and Game Positioning System (GPS).
All standard VEXcode VR Blocks are available for use in the V5RC 25-26 Push Back Playground.
Below is a list of all available Playground-specific Blocks:
Motion – Move and track the robot’s motors.
  • Actions
    • spin – Spins the selected motor or motor group indefinitely.
    • spin for – Spins a motor or group for a specific distance in degrees or turns.
    • spin to position – Spins a motor or motor group to a set position.
    • stop motor – Stops a specific motor or motor group from spinning.
  • Settings
    • set motor velocity – Sets the speed of a motor or motor group as a percentage.
    • set motor timeout – Limits how long a motor block waits before giving up if movement is blocked.
  • Position
    • motor position – Returns the motor’s current rotational position in degrees or turns.
    • set motor position – Sets the encoder value of a motor or motor group.
  • Values
    • motor is done? – Returns a Boolean indicating whether the motor is no longer spinning.
    • motor is spinning? – Returns a Boolean indicating whether the motor is currently spinning.
    • motor velocity – Returns the motor’s current velocity in %.
AI Vision – Capture and analyze objects using the AI Vision Sensor.
Sensing – Utilize the robot’s various sensors.
The examples in this project use the default Playground start position.
Motion#
Actions#
spin#
The spin block spins a selected motor or motor group in a specified direction using the current motor velocity.
    spin [ConveyorMotor v] [up v]
Parameters
Description
motor
The motor group to spin:
  • ConveyorMotor
  • IntakeMotor
direction
The direction to spin:
    ConveyorMotor
    • up
    • down
    IntakeMotor
    • intake
    • outtake
Example
    when started
    [Pick up a second Block.]
    spin [ConveyorMotor v] [up v] for [200] [degrees v] ▶
    spin [IntakeMotor v] [intake v]
    drive [forward v] for [350] [mm v] ▶
spin for#
The spin for block spins a selected motor or motor group for a specific amount of rotation using the current motor velocity, measured in degrees or turns.
    spin [ConveyorMotor v] [up v] for (90) [degrees v] ▶
Parameters
Description
motor
  • ConveyorMotor
  • IntakeMotor
direction
    ConveyorMotor
    • up
    • down
    IntakeMotor
    • intake
    • outtake
distance
The rotation amount, as an integer or decimal.
unit
The unit of measurement representing the distance:
  • degrees
  • turns
expanding arrow
By default, this is a waiting block, so the motor will finish moving before running the next block. To make the motor start moving and immediately run the next block right away, expand the block to say and don’t wait.
Example
    when started
spin to position#
The spin to position block spins a motor or motor group to a specific absolute position using the current motor velocity and motor position.
    spin [ConveyorMotor v] to position (90) [degrees v] ▶
Parameters
Description
motor
  • ConveyorMotor
  • IntakeMotor
position
The target position to spin the motor group to.
unit
The unit of measurement:
  • degrees
  • turns
expanding arrow
Example
    when started
    spin [ConveyorMotor v] to position [200] [degrees v] ▶
stop motor#
The stop motor block immediately stops the selected motor or motor group.
    stop [ConveyorMotor v]
Parameters
Description
motor
The motor group to stop:
  • ConveyorMotor
  • IntakeMotor
Example
    when started
    stop [IntakeMotor v]
Settings#
set motor velocity#
The set motor velocity block sets the default spinning speed of a motor or motor group as a percentage for all subsequent Motor blocks in the project.
    set [ConveyorMotor v] velocity to [50] [% v]
Parameters
Description
motor
The motor group to set the velocity of:
  • ConveyorMotor
  • IntakeMotor
velocity
Sets the default movement velocity from 0 to 100 as a percent.
unit
The unit that represents the velocity:
Example
    when started
    set [ConveyorMotor v] velocity to [100] [% v]
    drive [forward v] for [400] [mm v] ▶
set motor timeout#
The set motor timeout block sets a time limit for how long a Motor block will wait to reach its target. If the robot cannot complete the movement within the set time, it will stop automatically and continue with the next block.
Note: The Motor’s time limit is used to prevent Motor blocks that do not reach their target position from stopping the execution of other blocks in the stack.
    set [ConveyorMotor v] timeout to [1] seconds
Parameters
Description
motor
The motor group to set the timeout of:
  • ConveyorMotor
  • IntakeMotor
time
The maximum number of seconds a Motor block will run before stopping and moving to the next block.
Example
    when started
    set [ConveyorMotor v] timeout to [0.5] seconds
    spin [ConveyorMotor v] to position [1000] [degrees v] ▶
Position#
motor position#
The motor position block returns the total distance the selected motor or motor group has rotated.
    ([ConveyorMotor v] position in [degrees v])
Parameters
Description
motor
The motor group to return the position of:
  • ConveyorMotor
  • IntakeMotor
unit
  • degrees
  • turns
Example
    when started
    while <([ConveyorMotor v] position in [degrees v]) [math_less_than v] [200]>
    end
set motor position#
The set motor position block sets a specific position value to a motor or motor group, which updates the encoder reading.
    set [ConveyorMotor v] position to (0) [degrees v]
Parameters
Description
motor
The motor group to set the position of:
  • ConveyorMotor
  • IntakeMotor
position
The encoder position value to set.
unit
  • degrees
  • turns
Example
    when started
    set [ConveyorMotor v] position to [-200] [degrees v]
    spin [ConveyorMotor v] to position [0] [degrees v] ▶
Values#
motor is done#
The motor is done? block returns a Boolean indicating whether the motor or motor group is not spinning.
  • True – The motor is not spinning.
  • False – The motor is spinning.
    <[ConveyorMotor v] is done?>
Parameters
Description
motor
The motor group to check if it isn’t spinning:
  • ConveyorMotor
  • IntakeMotor
Example
    when started
    spin [ConveyorMotor v] to position [300] [degrees v] ◀ and don't wait
    drive [forward v]
    wait until <[ConveyorMotor v] is done?>
    stop driving
motor is spinning?#
The motor is spinning? block returns a Boolean indicating whether the motor is spinning.
  • True – The motor is spinning.
  • False – The motor is not spinning.
    <[ConveyorMotor v] is spinning?>
Parameters
Description
motor
The motor group to check if it is spinning:
  • ConveyorMotor
  • IntakeMotor
Example
    when started
    wait [0.1] seconds
    while <[ConveyorMotor v] is spinning?>
    drive [forward v] for [200] [mm v] ▶
motor velocity#
The motor velocity block returns the current rotational speed of the motor or motor group in a range from -100% to 100%.
    ([ConveyorMotor v] velocity in [% v] :: custom-motion)
Parameters
Description
motor
The motor group to return the velocity of:
  • ConveyorMotor
  • IntakeMotor
unit
Example
    when started
    wait [0.2] seconds
    print ([ConveyorMotor v] velocity in [% v] :: custom-motion) ▶
AI Vision#
Actions#
get object data#
The get object data block filters data from the AI Vision Sensor frame. The AI Vision Sensor can detect Game Elements on the field.
The dataset stores objects ordered from largest to smallest by width, starting at index 0. Each object’s properties can be accessed using AI Vision object property block. An empty dataset is returned if no matching objects are detected.
The Get object data stack block.#
  get [AI Classifications v] data from AI Vision
Parameter
Description
signature
Filters the dataset to only include data of the given signature. The only available signature is:
  • AI Classifications – Detects Red and Blue Blocks.
Example
    when started
    [If an object is detected, pick it up.]
    forever
    get [AI Classifications v] data from [AIVision v]
    if <[AIVision v] object exists?> then
    drive [forward v]
    wait until <[Bumper v] pressed?>
    stop driving
    break
Settings#
set object item#
The set object item block sets which item in the dataset to use.
The Set AI Vision object item stack block.#
  set [AIVision v] object item to [1]
Parameters
Description
item
The number of the item in the dataset to use.
Example
    when started
    [Display what object is farthest away.]
    forever
    set [AIVision v] object item to ([AIVision v] object count)
    clear all rows
    if <[AIVision v] object is [BlueBlock v]?> then
    print [Blue Block farthest away.] ▶
    else
    print [Red Block farthest away.] ▶
Values#
object exists?#
The object exists? block returns a Boolean indicating whether any object is detected in the dataset.
  • True – The dataset includes a detected object.
  • False – The dataset does not include any detected objects.
The AI Vision object exists Boolean block.#
  <AI Vision object exists?>
Parameters
Description
This block has no parameters.
Example
    when started
    [If an an object is detected, pick it up.]
    forever
    drive [forward v]
    stop driving
    break
AI Classification is#
The AI Vision object is? block returns a Boolean indicating whether a detected object matches a specific classification.
  • True – The item in the dataset is the specific object.
  • False – The item in the dataset is not the specific object.
The AI Vision AI Classification is object Boolean block.#
  <[AIVision] object is [BlueBlock v]?>
Parameter
Description
object
Which object to compare the item to:
  • sports ball
  • orange barrel
  • blue barrel
  • AIM robot
Example
    when started
    forever
    clear all rows
    else
object count#
The object count block returns the number of detected objects in the dataset as an integer.
  ([AIVision] object count)
Parameters
Description
Example
    when started
    forever
    clear all rows
    else
object property#
There are six properties that are included with each object (shown below) stored after the get object data block is used.
The AI Vision object property reporter block.#
  ([AIVision v] object [width v])
Some property values are based off of the detected object’s position in the AI Vision Sensor’s view at the time that the get object data block was used. The AI Vision Sensor has a resolution of 320 by 240 pixels.
Parameter
Description
property
Which property of the detected object to use:
width#
width returns the width of the detected object in pixels as an integer from 1 to 320.
The AI Vision object property stack block with its parameter set to width.#
Example
    when started
    [If an an object is detected, approach and pick it up.]
    forever
    if <([AIVision v] object [width v]) [math_greater_than v] [65]> then
    stop driving
    break
    else
    drive [forward v]
height#
height returns the height of the detected object in pixels as an integer from 1 to 240.
The AI Vision object property stack block with its parameter set to height.#
  ([AIVision v] object [height v])
Example
    when started
    forever
    if <([AIVision v] object [height v]) [math_greater_than v] [55]> then
    stop driving
    break
    else
    drive [forward v]
centerX#
centerX returns the x-coordinate of the center of the detected object in pixels as an integer from 0 to 320.
The AI Vision object property stack block with its parameter set to centerX.#
  ([AIVision v] object [centerX v])
Example
  when started
  [Pick up a Block from the top left group.]
  turn [left v] for [80] degrees ▶
  drive [forward v] for [100] [mm v] ▶
  set turn velocity to [20] [% v]
  turn [left v]
  forever
  if <<[140] [math_less_than v] ([AIVision v] object [centerX v])> and <([AIVision v] object [centerX v]) [math_less_than v] [180]>> then
  drive [forward v]
  stop driving
centerY#
centerY returns the y-coordinate of the center of the detected object in pixels as an integer from 0 to 240.
The AI Vision object property stack block with its parameter set to centerY.#
  ([AIVision v] object [centerY v])
Example
    when started
    forever
    if <([AIVision v] object [centerY v]) [math_greater_than v] [140]> then
    stop driving
    break
    else
    drive [forward v]
originX#
originX returns the x-coordinate of the top-left corner of the detected object’s bounding box in pixels as an integer from 0 to 320.
The AI Vision object property stack block with its parameter set to originX.#
  ([AIVision v] object [originX v])
Example
  when started
  turn [left v]
  forever
  if <<[100] [math_less_than v] ([AIVision v] object [originX v])> and <([AIVision v] object [originX v]) [math_less_than v] [140]>> then
  drive [forward v]
  stop driving
originY#
originY returns the y-coordinate of the top-left corner of the detected object’s bounding box in pixels as an integer from 0 to 240.
The AI Vision object property stack block with its parameter set to originY.#
  ([AIVision v] object [originY v])
Example
    when started
    forever
    if <[120] [math_less_than v] ([AIVision v] object [originY v])> then
    stop driving
    break
    else
    drive [forward v]
    end
    end
Sensing#
Optical#
Optical found object?#
The Optical found object? block returns a Boolean indicating whether the Optical Sensor has detected an object.
  • True – The Optical Sensor has detected an object.
  • False – The Optical Sensor has not detected an object.
    <[Optical v] found an object?>
Parameters
Description
Example
    when started
    [Move the preloaded Block to the top of the Conveyor.]
    wait until <[Optical v] found an object?>
Optical detects color?#
The Optical detects color? block returns a Boolean indicating whether the Optical Sensor has detected a specific color.
  • True – The Optical Sensor has detected the specified color.
  • False – The Optical Sensor has not detected the specified color.
    <[Optical v] detects [red v]?>
Parameters
Description
color
Which color to check for:
  • red
  • green
  • blue
  • yellow
  • orange
  • purple
Example
    when started
    [Pick up and move a Blue Block to the top of the Conveyor.]
    drive [forward v] for [360] [mm v] ▶
    wait until <[Optical v] detects [blue v]?>
Optical brightness#
The Optical brightness block returns the amount of light detected by the Optical Sensor in a range from 0% to 100%.
    ([Optical v] brightness in %)
Parameters
Description
Example
    when started
    wait until <[0] [math_less_than v] ([Optical v] brightness in %)>
Optical hue#
The Optical hue block returns the hue value of the color detected by the Optical Sensor.
Hue values range from 0 to 359 degrees, corresponding to positions on the color wheel shown below.
A circular color wheel displaying a full spectrum of hues labeled with degree values around the perimeter, increasing in 30-degree increments from 0° at the top to 360°.
    ([Optical v] hue in degrees)
Parameters
Description
Example
    when started
    wait until <[240] [math_equal v] ([Optical v] hue in degrees)>
when Optical#
The when Optical block runs its stack when the Optical Sensor detects or loses an object. You can have multiple when Optical blocks to run multiple stacks of blocks at once.
    when [Optical v] [detects v] an object
Parameters
Description
action
Which action to trigger the hat block:
  • detects
  • loses
Example
Example coming soon!
GPS#
GPS position#
The GPS position block returns the positional offset of the robot’s turning reference point from the center of a field with the GPS (Game Positioning System™) Sensor.
    ([GPS v] position [X v] in [mm v])
Parameters
Description
axis
Which acis to report:
  • X
  • Y
units
The unit to represent the position:
  • mm
  • inches
Example
    when started
    drive [forward v]
    wait until <[-450] [math_greater_than v] ([GPS v] position [Y v] in [mm v])>
    stop driving
GPS heading#
The GPS heading block returns the heading that the robot is currently facing based on the GPS (Game Positioning System™) Sensor’s readings from the VEX GPS Field Code from 0.00 to 359.99 degrees.
    ([GPS v] heading in degrees)
Parameters
Description
Example
    when started
    [Score the preloaded Block into a Center Goal.]
    turn [left v]
    wait until <[40] [math_greater_than v] ([GPS v] heading in degrees)>
    drive [forward v] for [1000] [mm v] ▶
    turn [right v]
    wait until <([GPS v] heading in degrees) [math_greater_than v] [310]>
    drive [reverse v] for [200] [mm v] ▶
