Field Details#
The VIQRC Virtual Skills - Pitching In Playground occupies an area measuring 1800 millimeters (about 6 feet) long and 2400 millimeters (about 8 feet) wide.
The field is 5 full black squares and two half-squares long and 7 full black squares and two half-squares wide.
Grid |
Measurement |
A full black square measures 300mm by 300mm (approximately 12 inches by 12 inches). |
A half black square measures 150mm by 300 mm (approximately 6 inches by 12 inches). |
Game Elements#
There are forty-five (45) Discs that start on the field in Dispensers.
Game Element |
Measurements |
Amount on Field |
- A yellow, padded, roughly spherical object, with an overall diameter of approximately 3” (76.2mm) and a weight of approximately 25g. |
22 |
Field Starting Configurations#
There are 8 total starting positions you can choose to start your robot from, labeled A through H. By default, the robot starts on position F.
