Robot Specific Python#
All standard VEXcode VR commands are available for use in the VIQRC Virtual Skills - Pitching In Playground.
Motion#
motor.spin()#
The motor.spin(direction) command is used to spin a motor indefinitely.
This is a non-waiting command and allows any subsequent commands to execute without delay.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.spin(direction).
Objects |
Description |
Spins Snapshot’s Intake to pick up Balls from the Field. |
Raises or lowers the catapult. |
Raises or lowers the catapult’s tension, affecting the distance the Ball will be catapulted. |
Parameters |
Description |
The direction for the motor to move in: |
Returns: None.
def main():
# Spin the intake motor forward.
intake_motor.spin(FORWARD)
# Wait half a second.
wait(0.5, SECONDS)
# Stop spinning the intake motor group.
intake_motor.stop()
motor.spin_for()#
The motor.spin_for(direction, distance, units, wait) command is used to spin a motor for a given amount of degrees or turns.
This is can be a non-waiting or waiting command depending on if the wait parameter is used.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.spin_for(direction, distance, units, wait).
Objects |
Description |
Parameters |
Description |
The distance for the motor to move as an integer. |
The units that the motor will use: |
Optional. The wait parameter determines whether the command will block subsequent commands ( |
Returns: None.
def main():
# Spin the intake motor forward for 1 turn.
intake_motor.spin_for(FORWARD, 1, TURNS)
motor.spin_to_position()#
The motor.spin_to(angle, units, wait) command is used to spin a motor to a given position.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.spin_for(angle, units, wait).
Objects |
Description |
Parameters |
Description |
The specific angle or number of turns that the motor will spin to. |
Returns: None.
def main():
# Spin the intake motor to 55 degrees.
intake_motor.spin_to_position(55, DEGREES)
motor.stop()#
The motor.stop() command is used to stop a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.stop().
Objects |
Description |
Returns: None.
def main():
# Wait one second.
wait(1, SECONDS)
intake_motor.stop()
motor.set_position()#
The motor.set_position(position, units) command is used to set a motor’s encoder position to the given position value.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_position(position, units).
Objects |
Description |
Parameters |
Description |
The specific integer for the IQ Motor’s encoder to be set to. |
The units for the motor to use: |
Returns: None.
def main():
# Set the current motor position to 90 degrees.
intake_motor.set_position(90, DEGREES)
# Spin the intake motor back to 0 degrees.
intake_motor.spin_to_position(0, DEGREES)
motor.set_velocity()#
The motor.set_velocity(velocity, units) command is used to set the speed of a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_velocity(velocity, units).
Objects |
Description |
Parameters |
Description |
The speed that the IQ Motor will spin at, ranging from -100 to 100. |
The unit for the Motor’s velocity, |
Returns: None.
def main():
# Set the intake motor velocity to 75 percent.
intake_motor.set_velocity(75, PERCENT)
# Spin the intake motor to 180 degrees.
intake_motor.spin_to_position(180, DEGREES)
motor.set_timeout()#
The motor.set_timeout(value, units) command is used to set a time limit for a motor’s movement commands.
This prevents motion commands that do not reach their intended position from preventing subsequent commands from running.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_timeout(value, units).
Objects |
Description |
Parameters |
Description |
The amount of time the motor will wait before stopping. |
The unit for the Motor’s timer, |
Returns: None.
def main():
# Set the intake motor's timeout to 2 seconds.
intake_motor.set_timeout(2, SECONDS)
# Spin the intake motor to 270 degrees.
intake_motor.spin_to_position(270, DEGREES)
Events#
intake_bumper.pressed()#
intake_bumper.pressed(callback) is the same command as bumper.pressed(callback).
The command only uses Fling’s specific bumper sensor intake_bumper to replace bumper in the standard command.
intake_bumper.released()#
intake_bumper.released(callback) is the same command as bumper.released(callback).
Sensing#
motor.is_done()#
The motor.is_done() command is used to return a True or False value if the selected motor has completed its movement.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.is_done().
Objects |
Description |
Returns: This returns a Boolean value.
def main():
# Move the Arm so it doesn't block the Front Distance Sensor.
intake_motor.spin_to_position(1000, DEGREES)
# Wait until the intake_motor has finished moving.
if intake_motor.is_done():
# Print the distance from the Front Distance Sensor to the closest
# object in front of it.
brain.screen.print(front_distance.object_distance(MM))
motor.is_spinning()#
The motor.is_spinning() command is used to return a True or False value if the selected motor is moving.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.is_spinning().
Objects |
Description |
# Example coming soon.
motor.position()#
The motor.position(units) command is used to return the current rotational position of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.position(units).
Objects |
Description |
Parameters |
Description |
The unit of the returned value, |
Returns: This returns a numerical value.
def main():
# Print the current position of the intake_motor_group in degrees.
brain.screen.print(intake_motor_group.position(DEGREES))
motor.velocity()#
The motor.velocity(units) command is used to return the current velocity of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.velocity(units).
Objects |
Description |
Parameters |
Description |
The unit of the motor’s velocity, |
def main():
# Print the current velocity of the intake_motor.
brain.screen.print(intake_motor_group.velocity(PERCENT))
intake_bumper.pressing()#
intake_bumper.pressing() is the same command as bumper.pressing().
The command only uses Fling’s specialized Bumper Sensor intake_bumper to replace bumper in the standard command.
For information on how to use the bumper.pressing() command, go to its API documentation here.
distance.object_distance()#
The distance.object_distance(units) command is used to report the distance of the nearest object from the Distance Sensor.
Parameters |
Description |
The unit of the reported distance, |
Returns: This returns a numeric value.
def main():
# Print the current distance to the nearest object in MM.
brain.print(distance.object_distance(MM))
distance.is_object_detected()#
The distance.is_object_detected() command is used to report a Boolean value if the Distance sensor sees an object within its field of view.
Returns: This reports a Boolean value.
def main():
# Print if the Distance Sensor detects an object in its Field of View.
brain.print(distance.is_object_detected())
color.is_near_object()#
The color.is_near_object() command is used to report a Boolean value if the Color Sensor is close enough to an object to detect a color.
def main():
# Print if the Color Sensor is detecting a color.
brain.print(color.is_near_object())
color.color()#
The color.color() command is used to return the color detected by a VEX IQ Optical Sensor.
The following colors can be used as a comparison to the color detected by an IQ Optical Sensor:
Color.REDColor.GREENColor.BLUEColor.YELLOWColor.ORANGEColor.PURPLEColor.CYAN
def main():
# Print the color of the object that the Front Optical Sensor sees.
brain.print(color.color())
color.brightness()#
The color.brightness() command is used to report the amount of light detected by a VEX IQ Optical Sensor within a range of 0 to 100 percent.
def main():
# Print the brightness of the object in front of Fling.
brain.print(color.brightness())
color.hue()#
The color.brightness() command is used to report the hue of the object detected by a VEX IQ Optical Sensor within a range of 0 to 359. This number represents the location of the detected color on a color wheel.
def main():
# Print the hue of the object in front of Fling.
brain.screen.print("Hue: ", optical.hue())
