Field Details#
The VIQRC 25-26 Mix & Match Playground occupies an area measuring 1800 millimeters (about 6 feet) long and 2400 millimeters (about 8 feet) wide.
The field is 5 full black squares and two half-squares long and 7 full black squares and two half-squares wide.
Grid |
Measurement |
A full black square measures 300mm by 300mm (approximately 12 inches by 12 inches). |
A half black square measures 150mm by 300 mm (approximately 6 inches by 12 inches). |
Game Elements#
The field has four different Scoring Elements, blue, red, and orange Pins and Beams.
Game Element |
Measurements |
Amount on Field |
A pin measuring approximately 3.5 inches in diameter and 4.57 inches tall. |
30 |
A beam that Pins can be placed into for more points. It measure approximately 9.88 inches long and 4.88 inches wide. |
2 |
