Robot Specific Blocks#
Introduction#
The VIQRC 25-26 Mix & Match Playground features blocks exclusive to the build designed for this Playground, including two motor options, IQ AI Vision Sensor, Optical Sensor, and Touch LED.
All standard VEXcode VR Blocks are available for use in the VIQRC 25-26 Mix & Match Playground.
Below is a list of all available Playground specific Blocks:
Motion – Move and track the robot’s motors.
Actions
spin – Spins the selected motor or motor group indefinitely.
spin for – Spins a motor or group for a specific distance in degrees or turns.
spin to position – Spins a motor or motor group to a set position.
stop motor – Stops a specific motor or motor group from spinning.
Settings
set motor velocity – Sets the speed of a motor or motor group as a percentage.
set motor timeout – Limits how long a motor block waits before giving up if movement is blocked.
Position
motor position – Returns the motor’s current rotational position in degrees or turns.
set motor position – Sets the encoder value of a motor or motor group.
Values
motor is done? – Returns a Boolean indicating whether the motor is no longer spinning.
motor is spinning? – Returns a Boolean indicating whether the motor is currently spinning.
motor velocity – Returns the motor’s current velocity in %.
AI Vision – Capture and analyze objects using the IQ AI Vision Sensor.
Actions
get object data – Captures data for a specific object type, such as colors, pre-trained objects, or AprilTags.
Settings
set object item – Selects a specific object from the list.
Values
object exists? – Returns whether any classification was detected.
object count – Returns how many objects were detected.
object property – Returns details such as:
AI Classification is – Returns if a specific classification is detected.
Sensing - Utilize the robot’s various sensors.
Optical
Optical found object? – Returns whether an object is detected.
Optical detects color? – Returns whether a specific color is detected.
Optical brightness – Returns the brightness percentage detected by the sensor.
Optical hue – Returns the hue value of the detected color.
when Optical – Executes the attached stack of blocks when the Optical Sensor detects or loses an object.
Touch LED
set TouchLED color – Sets the TouchLED to a selected color.
Motion#
Actions#
spin#
The spin block spins a selected motor or motor group in a specified direction using the current motor velocity.
spin [ClawMotor v] [open v]
Parameters |
Description |
motor |
The motor or motor group to spin:
direction |
The direction to spin:
Example
when started
[Place a pin atop another pin.]
spin [LiftMotor v] [up v] for [600] [degrees v] ▶
drive [forward v] for (140) [mm v] ▶
spin for#
The spin for block spins a selected motor or motor group for a specific amount of rotation using the current motor velocity, measured in degrees or turns.
spin [ClawMotor v] [open v] for (90) [degrees v] ▶
Parameters |
Description |
motor |
direction |
distance |
The rotation amount, as an integer or decimal. |
unit |
The unit of measurement representing the distance:
expanding arrow |
By default, this is a waiting block, so the motor will finish moving before running the next block. To make the motor start moving and immediately run the next block right away, expand the block to say and don’t wait. |
Example
when started
spin to position#
The spin to position block spins a motor or motor group to a specific absolute position using the current motor velocity and motor position.
spin [ClawMotor v] to position (90) [degrees v] ▶
Parameters |
Description |
motor |
position |
The target position to spin the motor or motor group to. |
unit |
The unit of measurement:
expanding arrow |
Example
when started
spin [LiftMotor v] to position [-2] [turns v] ▶
stop motor#
The stop motor block immediately stops the selected motor or motor group.
stop [ClawMotor v]
Parameters |
Description |
motor |
The motor or motor group to stop:
Example
when started
wait [2] seconds
stop [LiftMotor v]
Settings#
set motor velocity#
The set motor velocity block sets the default spinning speed of a motor or motor group as a percentage for all subsequent Motor blocks in the project.
set [ClawMotor v] velocity to (50) [% v]
Parameters |
Description |
motor |
The motor or motor group to set the velocity of:
velocity |
Sets the default movement velocity from 0 to 100 as a percent. |
unit |
The unit that represents the velocity:
Example
when started
set [LiftMotor v] velocity to [100] [% v]
set motor timeout#
The set motor timeout block sets a time limit for how long a Motor block will wait to reach its target. If the robot cannot complete the movement within the set time, it will stop automatically and continue with the next block.
Note: The Motor’s time limit is used to prevent Motor blocks that do not reach their target position from stopping the execution of other blocks in the stack.
set [ClawMotor v] timeout to (1) seconds
Parameters |
Description |
motor |
The motor or motor group to set the timeout of:
time |
The maximum number of seconds a Motor block will run before stopping and moving to the next block. |
Example
when started
set [LiftMotor v] timeout to [2] seconds
spin [LiftMotor v] [up v] for [5] [turns v] ▶
Position#
motor position#
The motor position block returns the total distance the selected motor or motor group has rotated.
([ClawMotor v] position in [degrees v])
Parameters |
Description |
motor |
The motor or motor group to return the position of:
unit |
Example
when started
wait until <[-600] [math_greater_than v] ([LiftMotor v] position in [degrees v])>
stop [LiftMotor v]
set motor position#
The set motor position block sets a specific position value to a motor or motor group, which updates the encoder reading.
set [ClawMotor v] position to (0) [degrees v]
Parameters |
Description |
motor |
The motor or motor group to set the position of:
position |
The encoder position value to set. |
unit |
Example
when started
set [LiftMotor v] position to [100] degrees
spin [LiftMotor v] to position [-500] [degrees v] ▶
Values#
motor is done#
The motor is done? block returns a Boolean indicating whether the motor or motor group is not spinning.
True – The motor is not spinning.
False – The motor is spinning.
<[ClawMotor v] is done?>
Parameters |
Description |
motor |
The motor or motor group to check if it is done spinning:
Example
when started
spin [LiftMotor v] [up v] for [600] [degrees v] ◀ and don't wait
wait [0.1] seconds
repeat until <[LiftMotor v] is done?>
set [TouchLED v] color to [red v]
wait [0.5] seconds
wait [0.5] seconds
end
motor is spinning?#
The motor is spinning? block returns a Boolean indicating whether the motor is spinning.
True – The motor is spinning.
False – The motor is not spinning.
<[ClawMotor v] is spinning?>
Parameters |
Description |
motor |
The motor or motor group to check if it is currently spinning:
Example
when started
wait [0.1] seconds
while <[LiftMotor v] is spinning?>
wait [0.5] seconds
wait [0.5] seconds
end
motor velocity#
The motor velocity block returns the current rotational speed of the motor or motor group in a range from -100% to 100%.
([ClawMotor v] velocity in [% v] :: custom-motion)
Parameters |
Description |
motor |
The motor or motor group to return the velocity of:
unit |
Example
when started
wait [0.5] seconds
print ([LiftMotor v] velocity in [% v] :: custom-motion) ▶
AI Vision#
Actions#
get object data#
The get object data block filters data from the IQ AI Vision Sensor frame. The IQ AI Vision Sensor can detect Game Elements on the field.
The dataset stores objects ordered from largest to smallest by width, starting at index 0. Each object’s properties can be accessed using AI Vision object property block. An empty dataset is returned if no matching objects are detected.
get [AI Classifications v] data from [AIVision v]
Parameter |
Description |
signature |
Filters the dataset to only include data of the given signature. The only available signature is:
Example
when started
[Place the Red Pin on the top left Blue Pin.]
turn [left v] for [38] degrees ▶
repeat until <([AIVision v] object [width v]) [math_greater_than v] [48]>
[Move forward until the robot is close to the Pin.]
drive [forward v]
end
drive [forward v] for [160] [mm v] ▶
Settings#
set object item#
The set object item block sets which item in the dataset to use.
set [AIVision v] object item to [1]
Parameters |
Description |
item |
The number of the item in the dataset to use. |
Example
when started
[Find the object index of the nearest Orange Pin.]
set [object_counter v] to [1]
[Iterate through all detected objects.]
repeat ([AIVision v] object count)
set [AIVision v] object item to (object_counter)
if <[AIVision v] object is [Orange Pin v] ?> then
print (join [Nearest Orange Pin is ] (object_counter)) ▶
else
change [object_counter v] by [1]
Values#
object exists?#
The object exists? block returns a Boolean indicating whether any object is detected in the dataset.
True – The dataset includes a detected object.
False – The dataset does not include any detected objects.
<AI Vision object exists?>
Parameters |
Description |
This block has no parameters. |
Example
when started
[Raise the Lift until a Pin or Beam is detected.]
repeat until <[AIVision v] object exists?>
end
stop [LiftMotor v]
object count#
The object count block returns the number of detected objects in the dataset as an integer.
Parameters |
Description |
Example
when started
else
object property#
There are six properties that are included with each object (shown below) stored after the get object data block is used.
Some property values are based off of the detected object’s position in the IQ AI Vision Sensor’s view at the time that the get object data block was used. The IQ AI Vision Sensor has a resolution of 320 by 240 pixels.
Parameter |
Description |
property |
Which property of the detected object to use: |
width#
width returns the width of the detected object in pixels as an integer from 1 to 320.
Example
when started
drive [forward v]
end
height#
height returns the height of the detected object in pixels as an integer from 1 to 240.
([AIVision v] object [height v])
Example
when started
repeat until <([AIVision v] object [height v]) [math_greater_than v] [68]>
drive [forward v]
end
centerX#
centerX returns the x-coordinate of the center of the detected object in pixels as an integer from 0 to 320.
([AIVision v] object [centerX v])
Example
when started
[Place the Red Pin on the bottom left Blue Pin.]
drive [forward v] for [50] [mm v] ▶
spin [LiftMotor v] [up v] for [450] [degrees v] ▶
set turn velocity to [10] [% v]
repeat until <([AIVision v] object [centerX v]) [math_less_than v] [190]>
[Turn until the robot is centered on the Blue Pin.]
turn [right v]
end
drive [forward v] for [350] [mm v] ▶
centerY#
centerY returns the y-coordinate of the center of the detected object in pixels as an integer from 0 to 240.
([AIVision v] object [centerY v])
Example
when started
repeat until <([AIVision v] object [centerY v]) [math_greater_than v] [210]>
drive [forward v]
end
originX#
originX returns the x-coordinate of the top-left corner of the detected object’s bounding box in pixels as an integer from 0 to 320.
([AIVision v] object [originX v])
Example
when started
repeat until <([AIVision v] object [centerX v]) [math_less_than v] [160]>
turn [right v]
end
originY#
originY returns the y-coordinate of the top-left corner of the detected object’s bounding box in pixels as an integer from 0 to 240.
([AIVision v] object [originY v])
Example
when started
repeat until <([AIVision v] object [originY v]) [math_greater_than v] [180]>
drive [forward v]
end
AI Classification is#
The AI Vision object is? block returns a Boolean indicating whether a detected object matches a specific classification.
True – The item in the dataset is the specific object.
False – The item in the dataset is not the specific object.
<[AIVision] object is [Beam v]?>
Parameter |
Description |
object |
Which object to compare the item to:
Example
when started
else
Sensing#
Optical#
Optical found object?#
The Optical found object? block returns a Boolean indicating whether the Optical Sensor has detected an object.
True – The Optical Sensor has detected an object.
False – The Optical Sensor has not detected an object.
<[Optical v] found an object?>
Parameters |
Description |
Example
when started
wait until <not <[Optical v] found an object?>>
spin [LiftMotor v] to position [0] [degrees v] ▶
Optical detects color?#
The Optical detects color? block returns a Boolean indicating whether the Optical Sensor has detected a specific color.
True – The Optical Sensor has detected the specified color.
False – The Optical Sensor has not detected the specified color.
<[Optical v] detects [red v]?>
Parameters |
Description |
color |
Which color to check for:
Example
when started
wait until <not <[Optical v] detects [red v]?>>
Optical brightness#
The Optical brightness block returns the amount of light detected by the Optical Sensor in a range from 0% to 100%.
([Optical v] brightness in %)
Parameters |
Description |
Example
when started
wait until <[30] [math_greater_than v] ([Optical v] brightness in %)>
Optical hue#
The Optical hue block returns the hue value of the color detected by the Optical Sensor.
Hue values range from 0 to 359 degrees, corresponding to positions on the color wheel shown below.
([Optical v] hue in degrees)
Parameters |
Description |
Example
when started
wait until <([Optical v] hue in degrees) [math_greater_than v] [0]>
when Optical#
The when Optical block runs its stack when the Optical Sensor detects or loses an object. You can have multiple when Optical blocks to run multiple stacks of blocks at once.
when [Optical v] [detects v] an object
Parameters |
Description |
action |
Which action to trigger the hat block:
Example
when started
when [Optical v] [loses v] an object
[Lower the lift when the red pin is not in the claw.]
Touch LED#
set TouchLED color#
The set TouchLED color block sets the color of the Touch LED.
set [TouchLED v] color to [none v]
Parameters |
Description |
color |
Sets the LED’s color to:
Example
when started
