Robot Specific Python#
Introduction#
The VIQRC 25-26 Mix & Match Playground features methods exclusive to the build designed for this Playground, including two motor options, IQ AI Vision Sensor, Optical Sensor, and Touch LED.
All standard VEXcode VR methods are available for use in the VIQRC 25-26 Mix & Match Playground.
Below is a list of all available Playground specific methods:
Motion – Move and track the robot’s motors.
Actions
spin– Spins the selected motor or motor group indefinitely.spin_for– Spins a motor or group for a specific distance in degrees or turns.spin_to_position– Spins a motor or motor group to a set position.stop– Stops a specific motor or motor group from spinning.
Mutators
set_position– Sets the encoder value of a motor or motor group.set_velocity– Sets the speed of a motor or motor group as a percentage.set_timeout– Limits how long a motor block waits before giving up if movement is blocked.
Getters
is_done– Returns a Boolean indicating whether the motor is no longer spinning.is_spinning– Returns a Boolean indicating whether the motor is currently spinning.position– Returns the motor’s current rotational position in degrees or turns.velocity– Returns the motor’s current velocity in % or rpm.
AI Vision - Capture and analyze objects using the IQ AI Vision Sensor.
Getters
take_snapshot– Returns a tuple of detected objects based on a given signature.
Properties
width– Width of the detected object in pixels.height– Height of the detected object in pixels.centerX– X position of the object’s center in pixels.centerY– Y position of the object’s center in pixels.originX– X position of the object’s top-left corner in pixels.originY– Y position of the object’s top-left corner in pixels.id– Classification or tag ID of the object.
Sensing - Utilize the robot’s various sensors.
Touch LED
set_color– Sets the TouchLED to a selected color.
Optical
is_near_object– Returns whether a detected object is near the Optical Sensor.color– Returns the color detected from the Optical Sensor.brightness– Returns the brightness percentage detected by the sensor.hue– Returns the hue value of the detected color.object_detected– Registers a callback function for when the Optical Sensor detects an object.object_lost– Registers a callback function for when the Optical Sensor loses an object.
Motion#
Actions#
spin#
spin spins a motor indefinitely.
Usage:
One of two available motor objects can be used with this method, as shown below:
motor |
Command |
Parameters |
Description |
The direction for the motor to spin:
def main():
# Place a Pin atop another Pin
lift_motor.spin_for(REVERSE, 600, DEGREES)
drivetrain.drive_for(FORWARD, 140, MM)
claw_motor.spin(FORWARD)
spin_for#
spin_for spins a motor for a given amount of degrees or turns.
Usage:
motor |
Command |
Parameters |
Description |
The distance for the motor to spin as an integer. |
The unit that represents the distance to rotate:
Optional.
def main():
spin_to_position#
spin_to spins a motor to a given position.
Usage:
motor |
Command |
Parameters |
Description |
The specific angle or number of turns that the motor will spin to. |
The unit that represents the angle to rotate to:
Optional.
def main():
lift_motor.spin_to_position(-2, TURNS)
stop#
stop stops a motor from spinning.
Usage:
motor |
Command |
Parameters |
Description |
This method has no parameters. |
def main():
lift_motor.spin(REVERSE)
wait(2, SECONDS)
lift_motor.stop()
Mutators#
set_position#
set_position sets a motor’s encoder position to the given position value.
Usage:
motor |
Command |
Parameters |
Description |
The specific integer for the motor’s encoder to be set to. |
def main():
lift_motor.set_position(100, DEGREES)
lift_motor.spin_to_position(-500, DEGREES)
set_velocity#
set_velocity sets the speed of a motor.
Usage:
motor |
Command |
Parameters |
Description |
The speed that the IQ Motor will spin at, ranging from 0 to 100. |
The unit that represents the new velocity:
def main():
lift_motor.set_velocity(100, PERCENT)
set_timeout#
set_timeout sets a time limit for a motor’s movement commands. This prevents motion commands that do not reach their intended position from preventing subsequent commands from running.
Usage:
motor |
Command |
Parameters |
Description |
The amount of time the motor will wait before stopping. |
The unit to represent the timeout:
def main():
lift_motor.set_timeout(2, SECONDS)
lift_motor.spin_for(REVERSE, 5, TURNS)
Getters#
is_done#
is_done returns a Boolean indicating whether the specified motor is not spinning.
True– The specified motor is not spinning.False– The specified motor is spinning.
Usage:
motor |
Command |
Parameters |
Description |
def main():
lift_motor.spin_for(REVERSE, 600, DEGREES, wait=False)
wait(0.1, SECONDS)
while not lift_motor.is_done():
touchled.set_color(RED)
wait(0.5, SECONDS)
touchled.set_color(NONE)
wait(0.5, SECONDS)
is_spinning#
is_spinning returns a Boolean indicating whether the specified motor is spinning.
True– The specified motor is spinning.False– The specified motor is not spinning.
Usage:
motor |
Command |
Parameters |
Description |
def main():
wait(0.1, SECONDS)
while lift_motor.is_spinning():
wait(0.5, SECONDS)
wait(0.5, SECONDS)
position#
position returns the total distance the specified motor has rotated.
Usage:
motor |
Command |
Parameters |
Description |
The units that represent the motor’s position:
def main():
while not -600 > claw_motor.position(DEGREES):
wait(2, MSEC)
lift_motor.stop()
velocity#
velocity returns the current rotational speed of the motor.
Usage:
motor |
Command |
Parameters |
Description |
The unit that represent the motor’s position:
def main():
wait(0.5, SECONDS)
brain.screen.print(lift_motor.velocity(PERCENT))
AI Vision#
Getters#
take_snapshot#
take_snapshot filters the data from the IQ AI Vision Sensor frame to return a tuple.
The tuple stores objects ordered from largest to smallest by width, starting at index 0. Each object’s properties can be accessed using its index. An empty tuple is returned if no matching objects are detected.
Usage:
ai_vision.take_snapshot(signature)
Parameters |
Description |
Which signature to get data of. The only available signature is:
def main():
# Place the Red Pin on the top left Blue Pin
drivetrain.turn_for(LEFT, 38, DEGREES)
ai_objects = ai_vision.take_snapshot(AiVision.ALL_AIOBJS)
while not ai_objects[0].width > 48:
# Move forward until the Robot is close to the Pin
drivetrain.drive(FORWARD)
drivetrain.drive_for(FORWARD, 160, MM)
vr_thread(main)
Properties#
There are seven properties that are included with each object stored in a tuple after take_snapshot is used.
Some property values are based off of the detected object’s position in the IQ AI Vision Sensor’s view at the time that take_snapshot was used. The IQ AI Vision Sensor has a resolution of 320 by 240 pixels.
.width#
.width returns the width of the detected object in pixels, which is an integer between 1 and 320.
def main():
vr_thread(main)
.height#
.height returns the height of the detected object in pixels, which is an integer between 1 and 240.
def main():
while not ai_objects[0].height > 68:
vr_thread(main)
.centerX#
.centerX returns the x-coordinate of the detected object’s center in pixels, which is an integer between 0 and 320.
def main():
# Place the Red Pin on the bottom left Blue Pin
drivetrain.drive_for(FORWARD, 50, MM)
lift_motor.spin_for(REVERSE, 450, DEGREES)
drivetrain.set_turn_velocity(10, PERCENT)
while not ai_objects[0].centerX < 190:
# Turn until the robot is centered on the Blue Pin
drivetrain.turn(RIGHT)
drivetrain.drive_for(FORWARD, 350, MM)
vr_thread(main)
.centerY#
.centerY returns the y-coordinate of the detected object’s center in pixels, which is an integer between 0 and 240.
def main():
while not ai_objects[0].centerY > 210:
drivetrain.drive_for(FORWARD, 190, MM)
vr_thread(main)
.originX#
.originX returns the x-coordinate of the top-left corner of the detected object’s bounding box in pixels, which is an integer between 0 and 320.
def main():
while not ai_objects[0].originX < 160:
vr_thread(main)
.originY#
.originY returns the y-coordinate of the top-left corner of the detected object’s bounding box in pixels, which is an integer between 0 and 240.
def main():
drivetrain.drive_for(FORWARD, 270, MM)
vr_thread(main)
.id#
.id returns the ID of the detected AI Classification as an integer.
AI Classification |
id |
Signature |
Beam |
0 |
Blue Pin |
1 |
Red Pin |
2 |
Orange Pin |
3 |
def main():
# Find the object index of the nearest Blue Pin
object_count = 1
# Iterate through all detected objects
if len(ai_objects) > 0:
for repeat_count in range(len(ai_objects)):
ai_objects_index = object_count - 1
if ai_objects[repeat_count].id == GameElements.BLUE_PIN:
brain.screen.print(str("Closest Blue Pin is ") + str(object_count))
else:
object_count = object_count + 1
vr_thread(main)
Sensing#
Touch LED#
set_color#
set_color sets the color of the Touch LED.
Usage:
touchled.set_color(color)
Parameters |
Description |
The color to set the Touch LED to:
def main():
Optical#
is_near_object#
is_near_object returns a Boolean indicating whether or not the Optical Sensor detects an object close to the sensor.
True– The object is close to the Optical Sensor.False– The object is not close to the Optical Sensor.
Usage:
optical.is_near_object()
Parameters |
Description |
def main():
while not not optical.is_near_object():
wait(2, MSEC)
lift_motor.spin_to_position(0, DEGREES)
color#
color returns the color detected by the Optical Sensor:
Color Returned: |
Usage:
optical.color()
Parameters |
Description |
def main():
while not optical.color() == RED:
wait(5, MSEC)
brightness#
brightness returns the brightness value detected by the Optical Sensor as a percent from 0% to 100%.
Usage:
optical.brightness()
Parameters |
Description |
def main():
while not 30 > optical.brightness():
wait(5, MSEC)
hue#
hue returns the hue detected by the Optical Sensor.
Hue values range from 0 to 359 degrees, corresponding to positions on the color wheel shown below.
Usage:
optical.hue()
Parameters |
Description |
def main():
while not optical.hue() > 0:
wait(5, MSEC)
object_detected#
object_detected registers a callback function for when the Optical Sensor detects an object.
Usage:
optical.object_detected(callback, arg)
Parameters |
Description |
A function that will be called when an object is detected. |
Optional. A tuple that is used to pass arguments to the callback function. |
def pin_in_open_claw():
# Change color when claw isn't holding anything
def main():
optical.object_detected(pin_in_open_claw)
touchled.set_color(GREEN)
object_lost#
object_lost registers a callback function for when the Optical Sensor loses an object.
Usage:
optical.object_lost(callback, arg)
Parameters |
Description |
A function that will be called when an object is lost. |
def lower_lift():
# Lower lift when Pin not in claw
def main():
optical.object_lost(lower_lift)
