Field Details#
The V5RC Virtual Skills - Spin Up Playground occupies an area measuring 3.65 meters (about 12 feet) long and 3.65 meters (about 12 feet) wide.
The field is 6 full tiles long and 6 full tiles wide.
Grid |
Measurement |
Each tile on the Field measures 600 mm by 600 mm. |
Game Elements#
The Field has one Game Element, Triballs.
Game Element |
Measurements |
Amount on Field |
A yellow foam object that can be manipulated by Robots. |
60 |
Field Starting Configurations#
The V5RC Virtual Skills - Spin Up Playground has access to a Pre-Match checklist to customize your robot’s starting conditions before running your code.
There are 10 total starting locations you can choose to start your robot from, labeled A through J. By default, the robot starts on position C.
You can also choose whether or not you want to preload your robot with 0, 1, or 2 Discs.
