Robot Details#
The V5RC Virtual Skills - Spin Up Playground uses the standard VEX V5 Hero Bot, Disco.
The Disco VEX V5 Hero Bot measures approximately 350 millimeters long and 280 millimeters wide.
Motor Groups#
Disco is equipped with two sets of Motor Groups for its Arm and Intake.
Configuration & |
Description |
API Documentation |
This allows the robot to collect and score discs. At the top of the intake is a set of two wheels. These can be used to spin the rollers. By spinning the intake motor group while the wheels are contacting the roller, the roller will spin and change color. |
Sensors#
Disco has access to the following sensors for autonomous coding:
Configuration |
Description |
API Documentation |
Python Command Name |
Brain Timer |
The Robot has access to a built-in timer. |
Drivetrain |
The Robot has access to a Drivetrain with a built-in Inertial Sensor to track the Robot’s current heading and angle of rotation. |
Bottom Distance |
Reports if an object is close to the sensor, as well the approximate distance from the front of the sensor to an object, in millimeters or inches. |
Line Trackers |
Located along the underside of Disco’s intake. These can be used to detect the position of discs within the intake and determine how many discs are currently being held in the intake. |
Roller Optical |
Reports if an object is close to the sensor, and if so, what color that object is. |
GPS |
Reports the current X and Y position of the center of rotation of Striker in millimeters or inches. The GPS Sensor can also report the current heading in degrees. |
The GPS sensor relies on the Cartesian Coordinate system to navigate, with the middle of the field being (0, 0).
