Robot Specific Python#
All standard VEXcode VR commands are available for use in the V5RC Virtual Skills - Spin Up Playground.
Motion#
motor.spin()#
The motor.spin(direction) command is used to spin a motor indefinitely.
This is a non-waiting command and allows any subsequent commands to execute without delay.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.spin(direction).
Objects |
Description |
Spins Disco’s Intake to pick up Game Elements from the Field. |
Parameters |
Description |
The direction for the motor to move in: |
Returns: None.
def main():
# Spin the intake motor forward.
intake_motor_group.spin(FORWARD)
# Wait half a second.
wait(0.5, SECONDS)
# Stop spinning the intake motor group.
intake_motor_group.stop()
motor.spin_for()#
The motor.spin_for(direction, distance, units, wait) command is used to spin a motor for a given amount of degrees or turns.
This is can be a non-waiting or waiting command depending on if the wait parameter is used.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.spin_for(direction, distance, units, wait).
Objects |
Description |
Parameters |
Description |
The distance for the motor to move as an integer. |
The units that the motor will use: |
Optional. The wait parameter determines whether the command will block subsequent commands ( |
Returns: None.
def main():
# Spin the intake motor forward for 1 turn.
intake_motor_group.spin_for(FORWARD, 1, TURNS)
motor.spin_to_position()#
The motor.spin_to(angle, units, wait) command is used to spin a motor to a given position.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.spin_for(angle, units, wait).
Objects |
Description |
Parameters |
Description |
The specific angle or number of turns that the motor will spin to. |
Returns: None.
def main():
# Spin the intake motor to 55 degrees.
intake_motor_group.spin_to_position(55, DEGREES)
motor.stop()#
The motor.stop() command is used to stop a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.stop().
Objects |
Description |
Returns: None.
def main():
wait(0.5, SECONDS)
motor.set_position()#
The motor.set_position(position, units) command is used to set a motor’s encoder position to the given position value.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_position(position, units).
Objects |
Description |
Parameters |
Description |
The specific integer for the Motor’s encoder to be set to. |
The units for the motor to use: |
Returns: None.
def main():
# Set the current motor position to 90 degrees.
intake_motor_group.set_position(90, DEGREES)
# Spin the intake motor back to 0 degrees.
intake_motor_group.spin_to_position(0, DEGREES)
motor.set_velocity()#
The motor.set_velocity(velocity, units) command is used to set the speed of a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_velocity(velocity, units).
Objects |
Description |
Parameters |
Description |
The speed that the Motor will spin at, ranging from -100 to 100. |
The unit for the Motor’s velocity, |
Returns: None.
def main():
# Set the intake motor velocity to 75 percent.
intake_motor_group.set_velocity(75, PERCENT)
# Spin the intake motor to 180 degrees.
intake_motor_group.spin_to_position(180, DEGREES)
motor.set_timeout()#
The motor.set_timeout(value, units) command is used to set a time limit for a motor’s movement commands.
This prevents motion commands that do not reach their intended position from preventing subsequent commands from running.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_timeout(value, units).
Objects |
Description |
Parameters |
Description |
The amount of time the motor will wait before stopping. |
The unit for the Motor’s timer, |
Returns: None.
def main():
# Set the intake motor's timeout to 2 seconds.
intake_motor_group.set_timeout(2, SECONDS)
# Spin the intake motor to 270 degrees.
intake_motor_group.spin_to_position(270, DEGREES)
Events#
roller_optical.object_detected()#
roller_optical.object_detected(callback) is the same command as eye.object_detected(callback).
The command only uses Disco’s Optical Sensor roller_optical to replace eye in the standard command.
roller_optical.object_lost()#
roller_optical.object_lost(callback) is the same command as eye.object_lost(callback).
Sensing#
motor.is_done()#
The motor.is_done() command is used to return a True or False value if the selected motor has completed its movement.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.is_done().
Objects |
Description |
Returns: This returns a Boolean value.
def main():
# Move the Arm so it doesn't block the Front Distance Sensor.
arm_motor_group.spin_to_position(1000, DEGREES)
# Wait until the arm_motor_group has finished moving.
if arm_motor_group.is_done():
# Print the distance from the Front Distance Sensor to the closest
# object in front of it.
brain.screen.print(front_distance.object_distance(MM))
motor.is_spinning()#
The motor.is_spinning() command is used to return a True or False value if the selected motor is moving.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.is_spinning().
Objects |
Description |
# Example coming soon.
motor.position()#
The motor.position(units) command is used to return the current rotational position of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.position(units).
Objects |
Description |
Parameters |
Description |
The unit of the returned value, |
Returns: This returns a numerical value.
def main():
# Print the current position of the intake_motor_group in degrees.
brain.screen.print(intake_motor_group.position(DEGREES))
motor.velocity()#
The motor.velocity(units) command is used to return the current velocity of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.velocity(units).
Objects |
Description |
Parameters |
Description |
The unit of the motor’s velocity, |
def main():
# Print the current velocity of the arm_motor_group.
brain.screen.print(arm_motor_group.velocity(PERCENT))
line_tracker.reflectivity()#
The line_tracker.reflectivity(units) command is used to return the amount of light reflected using the Line Tracker Sensor.
This command will report a range from 0% to 100%. Surfaces with lighter colors have higher reflectivity values, while darker surfaces have lower reflectivity values.
Parameters |
Description |
The unit of the reflected light, |
def main():
# Print the current reflectivity.
brain.screen.print(line_tracker.reflectivity(PERCENT))
roller_optical.is_near_object()#
The roller_optical.near_object() command is used to report a Boolean value if the Optical Sensor is close enough to an object to detect a color.
Returns: This reports a Boolean value.
def main():
# Print if the Front Optical Sensor is detecting a color.
brain.print(roller_optical.near_object())
roller_optical.color()#
The roller_optical.color() command is used to return the color detected by an Optical Sensor.
The following colors can be used as a comparison to the color detected by an Optical Sensor:
REDGREENBLUEYELLOWORANGEPURPLECYAN
Returns: This returns the name of the detected color as a string.
def main():
# Print the color of the object that the Front Optical Sensor sees.
brain.print(roller_optical.color())
roller_optical.brightness()#
The roller_optical.brightness() command is used to report the amount of light detected by an Optical Sensor within a range of 0 to 100 percent.
Returns: This returns a numeric value.
def main():
# Print the brightness of the object in front of Disco.
brain.print(roller_optical.brightness())
roller_optical.hue()#
The roller_optical.brightness() command is used to report the hue of the object detected by an Optical Sensor within a range of 0 to 359. This number represents the location of the detected color on a color wheel.
def main():
# Print the hue of the object in front of Disco.
brain.screen.print("Hue: ", optical.hue())
gps.x_position()#
The gps.x_position(units) command is used to report the X positional offset of a GPS Sensor or defined origin point from the center of a field.
Parameters |
Description |
The unit of the offset value, |
def main():
# Print the current X positional offset of the robot.
brain.screen.print(gps.x_position(MM))
gps.y_position()#
The gps.y_position(units) command is used to report the Y positional offset of a GPS Sensor or defined origin point from the center of a field.
Parameters |
Description |
def main():
# Print the current Y positional offset of the robot.
brain.screen.print(gps.y_position(MM))
gps.heading()#
The gps.heading() command is used to report the heading that a robot is currently facing based on a GPS Sensor’s readings from the VEX GPS Field Code.
def main():
# Print the current heading of the robot.
brain.screen.print(gps.heading())
