Σύνδεση δύο ρομπότ#
Linking Two Robots
This tutorial walks you through linking two VEX AIM Coding Robots. By the end, you’ll have two robots linked together and be able to see each one’s name on the other.
Make sure both robots are turned on and within Bluetooth range of one another.
  1. On both robots, navigate to Settings and select it.
Το εικονίδιο Ρυθμίσεις στο αρχικό μενού.
  1. Navigate to Link AIM and select it.
Το εικονίδιο Σύνδεσης AIM στο μενού Ρυθμίσεις.
  1. The linking animation will play while the robots are linking.
Η κινούμενη εικόνα Link AIM στην οθόνη του ρομπότ.
Note: When linking, a robot will try to connect with the closest robot to it. Be mindful of this if you are linking more than one pair of robots at the same time.
  1. Once linking is finished, the robots will show green, and the indicator icon in the top-left corner of the screen will show that the robots are linked.
Η κινούμενη εικόνα του ρομπότ έχει σταματήσει και είναι πλέον πράσινη. Ένα εικονίδιο επάνω αριστερά δείχνει τα συνδεδεμένα ρομπότ.
  1. To see the linked robot’s name, select the i at the bottom of the home menu to open the Info screen.
The i icon at the bottom of the robot's home menu.
  1. The linked robot’s name will appear at the bottom of the Info screen.
The Info screen showing the robot's own name and battery level, with the linked robot's name at the bottom.
