Ονομάζοντας το Ρομπότ#
Naming the Robot
This tutorial walks you through renaming your VEX AIM Coding Robot in VEXcode AIM. By the end, you’ll have given your robot a new name and viewed it both in VEXcode and on the robot.
Make sure your robot is connected to VEXcode. The robot icon will turn green and read Connected once it’s connected.
Select Connected in the top-right of VEXcode.
Select the Device Name field in the Robot section.
Type a new name for your robot, then press Enter.
Note: Spaces are not accepted. Use underscores to separate words, up to a maximum of 7 characters.
To see the name on the robot itself, press the i button at the bottom of the robot’s screen.
Θα εμφανιστεί το όνομα του ρομπότ και η στάθμη της μπαταρίας.
