Δημιουργία, Άνοιγμα και Αποθήκευση Έργου#
Creating, Opening, and Saving a Project
This tutorial walks you through creating, saving, and opening projects in VEXcode AIM. By the end, you’ll have made a new project, saved it to your device, and opened it again.
  1. Select File in the top-left of VEXcode.
Screenshot of the VEXcode AIM toolbar, with the File menu highlighted.
  1. Select New Project.
Screenshot of the File menu open, with the New Project option highlighted.
  1. Select Blocks or Python as the language for your project.
Screenshot of the New Project screen, with the Blocks and Python options under Project Language highlighted.
  1. Type a name for your project into the Project Name field.
Screenshot of the New Project screen, with the Project Name field highlighted. The name reads New Project Name.
  1. Select Save and Create Project to open the saving dialog for your device.
Screenshot of the New Project screen, with the Save and Create Project button highlighted.
  1. Select Save. A Windows device is shown here as an example.
Screenshot of the Windows file saving dialog, with the File name reading New Project Name and the Save button highlighted.
Note: Projects are saved with a .aimblocks or .aimpython extension, depending on whether it’s a Blocks or Python project.
  1. Once the project is saved, its name will appear at the top of VEXcode. VEXcode will also start auto-saving your project as you work.
Screenshot of the VEXcode AIM toolbar, showing the saved project name New Project Name with a checkmark icon.
  1. You can also save manually at any time. Select File, then select Save to save the project, or Save As to save it with a new name.
Screenshot of the File menu open, with the Save and Save As options highlighted.
  1. To open a saved project, select File, then select Open.
Screenshot of the File menu open, with the Open option highlighted.
  1. Navigate to and select the project file that you want to open, then select Open.
Screenshot of the Windows file picker, with a VEXcode AIM project file selected and the Open button highlighted.
  1. The project will appear in the workspace and its name will show at the top of VEXcode.
Screenshot of the VEXcode AIM toolbar, showing the opened project name New Project Name with a checkmark icon.
