Ρύθμιση παραμέτρων υπογραφών χρώματος#
This tutorial walks you through configuring a Color Signature for the AI Vision Sensor in VEXcode AIM. By the end, you’ll have a tuned Color Signature your projects can use to detect that color.
A Color Signature is one of two visual signatures used by the AI Vision Sensor to identify colors. It must be configured before the sensor can recognize it.
Note: A wired connection must be used to enable the AI Vision Utility and configure Color Signatures for the robot.
Select the Control Panel tab.
Select AI Vision.
Select Open AI Vision Utility.
Place a solid-colored object in front of the sensor.
Drag the cursor over the object. A red box will outline the selected color.
Σημείωση: Παραμείνετε εντός της χρωματικής περιοχής για να αποφύγετε τη συμπερίληψη χρωμάτων φόντου που θα μπορούσαν να επηρεάσουν την ανίχνευση.
Select Set Color. The sensor will save it as a Color Signature.
Rename the Color Signature by typing into the Name field.
Use the Hue slider to expand or narrow the range of colors around your selected hue. Increase the range until the target box fully surrounds the object.
Note: Don’t go too far, or the signature may include unwanted colors.
Use the Saturation slider to include lighter or dimmer versions of the color. Adjust it until the box stays locked on the object, even in different lighting.
Select Add Color to set more Color Signatures. The sensor can track up to 7 Color Signatures at a time.
Select Done.
All configured Color Signatures will now appear in the AI Vision tab of the Control Panel.
