机器人专用 Python#
所有标准 VEXcode VR 命令均可在 VIQRC 虚拟技能 - Pitching In 游乐场中使用。
运动#
motor.spin()#
The motor.spin(direction) command is used to spin a motor indefinitely.
这是一个非等待命令,允许任何后续命令无延迟地执行。
To use this command, replace motor with the desired motor or motor group, for example: intake_motor.spin(direction).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
提高或降低弹射器的张力,影响球被弹射的距离。 |
参数 |
描述 |
The direction for the motor to move in: |
**返回:**无。
def main():
# Spin the intake motor forward.
intake_motor.spin(FORWARD)
# Wait half a second.
wait(0.5, SECONDS)
# Stop spinning the intake motor group.
intake_motor.stop()
motor.spin_for()#
The motor.spin_for(direction, distance, units, wait) command is used to spin a motor for a given amount of degrees or turns.
This is can be a non-waiting or waiting command depending on if the wait parameter is used.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.spin_for(direction, distance, units, wait).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
参数 |
描述 |
电机移动的距离,为整数。 |
The units that the motor will use: |
Optional. The wait parameter determines whether the command will block subsequent commands ( |
**返回:**无。
def main():
# Spin the intake motor forward for 1 turn.
intake_motor.spin_for(FORWARD, 1, TURNS)
motor.spin_to_position()#
The motor.spin_to(angle, units, wait) command is used to spin a motor to a given position.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.spin_for(angle, units, wait).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
参数 |
描述 |
电机旋转的特定角度或圈数。 |
**返回:**无。
def main():
# Spin the intake motor to 55 degrees.
intake_motor.spin_to_position(55, DEGREES)
motor.stop()#
The motor.stop() command is used to stop a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.stop().
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
**返回:**无。
def main():
# Wait one second.
wait(1, SECONDS)
intake_motor.stop()
motor.set_position()#
The motor.set_position(position, units) command is used to set a motor’s encoder position to the given position value.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_position(position, units).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
参数 |
描述 |
IQ 电机编码器的具体整数设置。 |
The units for the motor to use: |
**返回:**无。
def main():
# Set the current motor position to 90 degrees.
intake_motor.set_position(90, DEGREES)
# Spin the intake motor back to 0 degrees.
intake_motor.spin_to_position(0, DEGREES)
motor.set_velocity()#
The motor.set_velocity(velocity, units) command is used to set the speed of a motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_velocity(velocity, units).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
参数 |
描述 |
IQ 电机旋转的速度,范围从 -100 到 100。 |
The unit for the Motor’s velocity, |
**返回:**无。
def main():
# Set the intake motor velocity to 75 percent.
intake_motor.set_velocity(75, PERCENT)
# Spin the intake motor to 180 degrees.
intake_motor.spin_to_position(180, DEGREES)
motor.set_timeout()#
The motor.set_timeout(value, units) command is used to set a time limit for a motor’s movement commands.
这可以防止未到达预定位置的运动命令阻止后续命令运行。
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.set_timeout(value, units).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
参数 |
描述 |
电机停止前等待的时间。 |
The unit for the Motor’s timer, |
**返回:**无。
def main():
# Set the intake motor's timeout to 2 seconds.
intake_motor.set_timeout(2, SECONDS)
# Spin the intake motor to 270 degrees.
intake_motor.spin_to_position(270, DEGREES)
活动#
intake_bumper.pressed()#
intake_bumper.pressed(callback) is the same command as bumper.pressed(callback).
The command only uses Fling’s specific bumper sensor intake_bumper to replace bumper in the standard command.
intake_bumper.released()#
intake_bumper.released(callback) is the same command as bumper.released(callback).
传感#
motor.is_done()#
The motor.is_done() command is used to return a True or False value if the selected motor has completed its movement.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.is_done().
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
**返回:**这将返回一个布尔值。
def main():
# Move the Arm so it doesn't block the Front Distance Sensor.
intake_motor.spin_to_position(1000, DEGREES)
# Wait until the intake_motor has finished moving.
if intake_motor.is_done():
# Print the distance from the Front Distance Sensor to the closest
# object in front of it.
brain.screen.print(front_distance.object_distance(MM))
motor.is_spinning()#
The motor.is_spinning() command is used to return a True or False value if the selected motor is moving.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.is_spinning().
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
**返回:**这将返回一个布尔值。
# Example coming soon.
motor.position()#
The motor.position(units) command is used to return the current rotational position of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.position(units).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
参数 |
描述 |
The unit of the returned value, |
**返回:**这将返回一个数值。
def main():
# Print the current position of the intake_motor_group in degrees.
brain.screen.print(intake_motor_group.position(DEGREES))
motor.velocity()#
The motor.velocity(units) command is used to return the current velocity of the selected motor.
To use this command, replace motor with the desired motor or motor group, for example: intake_motor_group.velocity(units).
对象 |
描述 |
旋转快照的进气口以从场地拾取球。 |
升起或降低弹射器。 |
参数 |
描述 |
The unit of the motor’s velocity, |
**返回:**这将返回一个数值。
def main():
# Print the current velocity of the intake_motor.
brain.screen.print(intake_motor_group.velocity(PERCENT))
intake_bumper.pressing()#
intake_bumper.pressing() is the same command as bumper.pressing().
The command only uses Fling’s specialized Bumper Sensor intake_bumper to replace bumper in the standard command.
For information on how to use the bumper.pressing() command, go to its API documentation here.
distance.object_distance()#
The distance.object_distance(units) command is used to report the distance of the nearest object from the Distance Sensor.
参数 |
描述 |
The unit of the reported distance, |
**返回:**这将返回一个数值。
def main():
# Print the current distance to the nearest object in MM.
brain.print(distance.object_distance(MM))
distance.is_object_detected()#
The distance.is_object_detected() command is used to report a Boolean value if the Distance sensor sees an object within its field of view.
**返回:**报告一个布尔值。
def main():
# Print if the Distance Sensor detects an object in its Field of View.
brain.print(distance.is_object_detected())
color.is_near_object()#
The color.is_near_object() command is used to report a Boolean value if the Color Sensor is close enough to an object to detect a color.
**返回:**报告一个布尔值。
def main():
# Print if the Color Sensor is detecting a color.
brain.print(color.is_near_object())
color.color()#
The color.color() command is used to return the color detected by a VEX IQ Optical Sensor.
以下颜色可用于与 IQ 光学传感器检测到的颜色进行比较:
Color.REDColor.GREENColor.BLUEColor.YELLOWColor.ORANGEColor.PURPLEColor.CYAN
**返回:**这将返回一个布尔值。
def main():
# Print the color of the object that the Front Optical Sensor sees.
brain.print(color.color())
color.brightness()#
The color.brightness() command is used to report the amount of light detected by a VEX IQ Optical Sensor within a range of 0 to 100 percent.
**返回:**这将返回一个数值。
def main():
# Print the brightness of the object in front of Fling.
brain.print(color.brightness())
color.hue()#
The color.brightness() command is used to report the hue of the object detected by a VEX IQ Optical Sensor within a range of 0 to 359. This number represents the location of the detected color on a color wheel.
**返回:**这将返回一个数值。
def main():
# Print the hue of the object in front of Fling.
brain.screen.print("Hue: ", optical.hue())
