Configuring a Drivetrain#
This tutorial walks you through configuring a Drivetrain in VEXcode V5. By the end, you’ll have added and configured a Drivetrain.
Select the Devices tab.
Select Add a Device.
Select Drivetrain 2-Motor.
Select the port that the left motor is connected to.
Select the port that the right motor is connected to.
Select No Sensor.
Select Done to add the Drivetrain to your robot.
The Drivetrain will now appear in your list of Devices.
The Drivetrain category will now appear in the toolbox, containing its blocks.
