机器人专用 Python#
介绍#
V5RC 25-26 Push Back 游乐场采用专为此游乐场设计的专属方法,包括两个电机选项、AI 视觉传感器、光学传感器和游戏定位系统 (GPS) 传感器。
所有标准 VEXcode VR 方法均可用于 V5RC 25-26 Push Back 游乐场。
以下是所有可用的 Playground 特定方法的列表:
运动——移动并跟踪机器人的马达。
行动
spin– Spins the selected motor or motor group indefinitely.spin_for– Spins a motor or group for a specific distance in degrees or turns.spin_to_position– Spins a motor or motor group to a set position.stop– Stops a specific motor or motor group from spinning.
修改器
set_position– Sets the encoder value of a motor or motor group.set_velocity– Sets the speed of a motor or motor group as a percentage.set_timeout– Limits how long a motor block waits before giving up if movement is blocked.
吸气剂
is_done– Returns a Boolean indicating whether the motor is no longer spinning.is_spinning– Returns a Boolean indicating whether the motor is currently spinning.position– Returns the motor’s current rotational position in degrees or turns.velocity– Returns the motor’s current velocity in % or rpm.
AI 视觉 - 使用 AI 视觉传感器捕捉和分析物体。
吸气剂
take_snapshot– Returns a tuple of detected objects based on a given signature.
特性
width– Width of the detected object in pixels.height– Height of the detected object in pixels.centerX– X position of the object’s center in pixels.centerY– Y position of the object’s center in pixels.originX– X position of the object’s top-left corner in pixels.originY– Y position of the object’s top-left corner in pixels.id– Classification or tag ID of the object.
感知——利用机器人的各种传感器。
光学的
is_near_object– Returns whether a detected object is near the Optical Sensor.color– Returns the color detected from the Optical Sensor.brightness– Returns the brightness percentage detected by the sensor.hue– Returns the hue value of the detected color.object_detected– Registers a callback function for when the Optical Sensor detects an object.object_lost– Registers a callback function for when the Optical Sensor loses an object.
全球定位系统
x_position– Returns the current x coordinate of a GPS Sensor on the Field.y_position–Returns the current y coordinate of a GPS Sensor on the Field.heading– Returns the heading that the robot is currently facing based on the GPS Sensor’s readings from 0 to 359 degrees.
运动#
Actions#
旋转#
spin spins a motor or motor group in the specified direction indefinitely.
用法:
两个可用电机对象之一可与此方法一起使用,如下所示:
发动机 |
命令 |
参数 |
描述 |
The direction for the motor to spin:
def main():
# Pick up a second Block
conveyor_motor.spin_for(FORWARD, 200, DEGREES)
intake_motor.spin(FORWARD)
drivetrain.drive_for(FORWARD, 350, MM)
spin_for#
spin_for spins a motor or motor group for a given amount of degrees or turns.
用法:
发动机 |
命令 |
参数 |
描述 |
电机旋转的距离,为整数。 |
The unit that represents the distance to rotate:
Optional.
def main():
旋转到位置#
spin_to spins a motor or motor group to a given position.
用法:
发动机 |
命令 |
参数 |
描述 |
电机旋转的特定角度或圈数。 |
The unit that represents the angle to rotate to:
Optional.
def main():
conveyor_motor.spin_to_position(150, DEGREES)
停止#
stop stops a motor or motor group from spinning.
用法:
发动机 |
命令 |
参数 |
描述 |
该方法没有参数。 |
def main():
intake_motor.stop()
Mutators#
设置位置#
set_position sets a motor’s or motor group’s encoder position to the given position value.
用法:
发动机 |
命令 |
参数 |
描述 |
要设置的电机编码器的具体整数。 |
def main():
conveyor_motor.set_position(-150, DEGREES)
conveyor_motor.spin_to_position(0, DEGREES)
设置速度#
set_velocity sets the speed of a motor or motor group.
用法:
发动机 |
命令 |
参数 |
描述 |
V5 电机旋转的速度,范围从 0 到 100。 |
The unit that represents the new velocity:
def main():
conveyor_motor.set_velocity(90, PERCENT)
drivetrain.drive_for(FORWARD, 400, MM)
设置超时#
set_timeout sets a time limit for a motor’s or motor group’s movement commands. This prevents Motion commands that do not reach their intended position from preventing subsequent commands from running.
用法:
发动机 |
命令 |
参数 |
描述 |
电机停止前等待的时间。 |
The unit to represent the timeout:
def main():
conveyor_motor.set_timeout(0.5, SECONDS)
conveyor_motor.spin_to_position(1000, DEGREES)
Getters#
完成#
is_done returns a Boolean indicating whether the specified motor or motor group is not spinning.
True– The specified motor is not spinning.False– The specified motor is spinning.
用法:
发动机 |
命令 |
参数 |
描述 |
该方法没有参数。 |
def main():
conveyor_motor.spin_to_position(300, DEGREES, wait=False)
wait(0.1, SECONDS)
while not conveyor_motor.is_done():
drivetrain.drive(FORWARD)
wait(5, MSEC)
drivetrain.stop()
intake_motor.stop()
正在旋转#
is_spinning returns a Boolean indicating whether the specified motor or motor group is spinning.
True– The specified motor is spinning.False– The specified motor is not spinning.
用法:
发动机 |
命令 |
参数 |
描述 |
该方法没有参数。 |
def main():
wait(0.1, SECONDS)
while conveyor_motor.is_spinning():
drivetrain.drive_for(FORWARD, 200, MM)
位置#
position returns the total distance the specified motor or motor group has rotated.
用法:
发动机 |
命令 |
参数 |
描述 |
The units that represent the motor’s position:
def main():
while conveyor_motor.position(DEGREES) < 150:
conveyor_motor.spin(FORWARD)
wait(2, MSEC)
conveyor_motor.stop()
速度#
velocity returns the current rotational speed of the motor or motor group.
用法:
发动机 |
命令 |
参数 |
描述 |
The unit that represent the motor’s position:
def main():
# Pick up a second block
conveyor_motor.set_velocity(100, PERCENT)
wait(0.2, SECONDS)
brain.screen.print(conveyor_motor.velocity(PERCENT))
人工智能视觉#
Getters#
拍摄快照#
take_snapshot filters the data from the AI Vision Sensor frame to return a tuple.
该元组存储的对象按宽度从大到小排序,从索引 0 开始。每个对象的 属性 可以通过其索引访问。如果未检测到匹配的对象,则返回一个空元组。
Usage:
ai_vision.take_snapshot(signature)
参数 |
描述 |
获取哪个签名的数据。唯一可用的签名是:
def main():
# If an object is detected, pick it up
while True:
ai_objects = ai_vision.take_snapshot(AiVision.ALL_AIOBJS)
if ai_objects:
while not bumper.pressing():
wait(2, MSEC)
drivetrain.stop()
break
Properties#
There are seven properties that are included with each object stored in a tuple after take_snapshot is used.
Some property values are based off of the detected object’s position in the AI Vision Sensor’s view at the time that take_snapshot was used. The AI Vision Sensor has a resolution of 320 by 240 pixels.
。宽度#
.width returns the width of the detected object in pixels, which is an integer between 1 and 320.
def main():
# If an object is detected, approach and pick it up
while True:
if ai_objects:
if ai_objects[0].width > 65:
drivetrain.stop()
break
else:
。高度#
.height returns the height of the detected object in pixels, which is an integer between 1 and 240.
def main():
while True:
if ai_objects:
if ai_objects[0].height > 55:
drivetrain.stop()
break
else:
.centerX#
.centerX returns the x-coordinate of the detected object’s center in pixels, which is an integer between 0 and 320.
def main():
# Pick up a Block from the top left group
drivetrain.turn_for(LEFT, 80, DEGREES)
drivetrain.set_turn_velocity(20, PERCENT)
drivetrain.turn(LEFT)
while True:
if ai_objects:
if 140 < ai_objects[0].centerX < 180:
wait(2, MSEC)
drivetrain.stop()
.centerY#
.centerY returns the y-coordinate of the detected object’s center in pixels, which is an integer between 0 and 240.
def main():
while True:
if ai_objects:
if ai_objects[0].centerY > 140:
drivetrain.stop()
break
else:
.originX#
.originX returns the x-coordinate of the top-left corner of the detected object’s bounding box in pixels, which is an integer between 0 and 320.
def main():
drivetrain.drive_for(FORWARD, 300, MM)
drivetrain.turn(RIGHT)
while True:
if ai_objects:
if 100 < ai_objects[0].originX < 140:
wait(2, MSEC)
drivetrain.stop()
.originY#
.originY returns the y-coordinate of the top-left corner of the detected object’s bounding box in pixels, which is an integer between 0 and 240.
def main():
while True:
if ai_objects:
if ai_objects[0].originY > 120:
drivetrain.stop()
break
else:
。ID#
.id returns the ID of the detected AI Classification as an integer.
人工智能分类 |
ID |
签名 |
蓝块 |
1 |
红块 |
2 |
def main():
# Pick up a Red Block from the top left group
while True:
if ai_objects:
if (ai_objects[0].id) == 2:
wait(2, MSEC)
drivetrain.stop()
break
传感#
Optical#
靠近物体#
is_near_object returns a Boolean indicating whether or not the Optical Sensor detects an object close to the sensor.
True– The object is close to the Optical Sensor.False– The object is not close to the Optical Sensor.
Usage:
optical.is_near_object()
参数 |
描述 |
该方法没有参数。 |
def main():
# Move the preloaded Block to the top of the Conveyor
while not optical.is_near_object():
wait(2, MSEC)
颜色#
color returns the color detected by the Optical Sensor:
返回的颜色: |
Usage:
optical.color()
参数 |
描述 |
该方法没有参数。 |
def main():
# Pick up and move a Blue Block to the top of the Conveyor
drivetrain.drive_for(FORWARD, 360, MM)
while not optical.color() == BLUE:
wait(2, MSEC)
亮度#
brightness returns the brightness value detected by the Optical Sensor as a percent from 0% to 100%.
Usage:
optical.brightness()
参数 |
描述 |
该方法没有参数。 |
def main():
while not 0 < optical.brightness():
wait(2, MSEC)
色调#
hue returns the hue detected by the Optical Sensor.
色调值范围从 0 到 359 度,对应于下面显示的色轮上的位置。
Usage:
optical.hue()
参数 |
描述 |
该方法没有参数。 |
def main():
while not 220 < optical.hue() < 260:
wait(2, MSEC)
检测到物体#
object_detected registers a callback function for when the Optical Sensor detects an object.
Usage:
optical.object_detected(callback, arg)
参数 |
描述 |
当检测到物体时调用的函数。 |
可选。用于将参数传递给回调函数的元组。 |
def ready_block():
# Stop the conveyor when Block is at the Sensor
def main():
# Move the preloaded Block near the top of the Conveyor
optical.object_detected(ready_block)
object_lost#
object_lost registers a callback function for when the Optical Sensor loses a previously detected object.
Usage:
optical.object_lost(callback, arg)
参数 |
描述 |
当检测到的对象丢失时将调用的函数。 |
def ready_block():
# Stop the conveyor when Block is at the top
def main():
optical.object_lost(ready_block)
GPS#
本页上的所有 GPS(游戏定位系统™)传感器示例均使用默认的 Playground 起始位置 C。
x_位置#
x_position returns the current x coordinate of a GPS (Game Positioning System™) Sensor on the Field.
Usage:
gps.x_position(units)
参数 |
描述 |
单位 |
The unit of the offset value, |
def main():
while not gps.x_position(MM) > -795:
wait(2, MSEC)
drivetrain.stop()
y_位置#
y_position returns the current y coordinate of a GPS (Game Positioning System™) Sensor on the Field.
Usage:
gps.y_position(units)
参数 |
描述 |
单位 |
def main():
while not -450 > gps.y_position(MM):
wait(2, MSEC)
drivetrain.stop()
标题#
heading returns the heading that the robot is currently facing based on the GPS (Game Positioning System™) Sensor’s readings from 0 to 359 degrees.
Usage:
gps.heading()
参数 |
描述 |
该方法没有参数。 |
def main():
# Score the preloaded Block into a Center Goal
drivetrain.set_turn_velocity(30, PERCENT)
while not 40 > gps.heading():
wait(2, MSEC)
drivetrain.drive_for(FORWARD, 1000, MM)
while not gps.heading() > 310:
wait(2, MSEC)
drivetrain.drive_for(REVERSE, 400, MM)
