Configuración del dispositivo: Tren motriz#
Add a Drivetrain#
Open the Devices Tab#
Select the Devices tab.
Screenshot of VEXcode's tab bar, with the Devices tab highlighted.
If the Devices tab is not visible, see Add a Tab in the Navigating VEXcode tutorial.
Select Add a Device#
Select Add a Device in the Devices tab.
Screenshot of the Devices tab, with the Add a Device button highlighted.
Select a Drivetrain#
Select Drivetrain 2-Motor or Drivetrain 4-Motor, depending on how many motors you’re using in your drivetrain.
Screenshot of the Select a device screen, with Drivetrain 2-Motor highlighted among the other device options.
Select the Left Motor Port(s)#
Select the ports for the motors that drive your robot’s left wheels.
Screenshot of the Left Motor port selection screen, showing ports 1 through 21 to choose from.
Select the Right Motor Port(s)#
Select the ports for the motors that drive your robot’s right wheels.
Screenshot of the Right Motor port selection screen, showing ports 1 through 21 to choose from.
Select a Sensor#
Select what sensor you want to use with your Drivetrain:
  • No Sensor — No Inertial, GPS, or Gyro Sensor will be connected to your Drivetrain. Blocks that rely on these sensors will not appear in your toolbox.
  • Inertial Sensor — Select the port for an Inertial Sensor to measure the drivetrain’s movements.
  • GPS Sensor — Select the port for a GPS Sensor to measure the drivetrain’s movements and field position.
  • 3-Wire Gyro — Select the port for a Gyro Sensor to measure the drivetrain’s movements.
Screenshot of the Select device option screen, showing Inertial Sensor, GPS Sensor, 3-Wire Gyro, and No Sensor options.
V5 has no built-in Inertial Sensor — unlike some other VEXcode platforms, an Inertial, GPS, or Gyro Sensor must be added separately to enable heading and rotation blocks.
If you selected Inertial Sensor, GPS Sensor, or 3-Wire Gyro, select the port it’s connected to.
Screenshot of the Inertial port selection screen, showing ports 1 through 21 to choose from.
Configure Your Drivetrain#
Adjust the Drivetrain Settings#
Configure your Drivetrain’s settings. If you’re using a pre-made build, the default values do not need to be changed.
  • Wheel Size — The diameter, or circumference, of your Drivetrain’s wheels: 2.75 inches (Dia.), 3.25 inches (Dia.), 4 inches (Dia.) (the default), 5 inches (Dia.), 6 inches (Dia.), or 200mm (Cir.) (SDV).
  • Gear Ratio — The ratio between the Input and Output gears, if your Drivetrain uses external gears. Use 1:1 if no external gears are used.
  • Direction — Select the up or down arrow to set which direction is forward for the Drivetrain.
Screenshot of the Drivetrain Settings screen, showing Wheel Size, Gear Ratio, Gear Cartridge, and Direction options.
Select the Motor Cartridge#
Select the color of the motors’ internal gear cartridges:
  • red (36:1, 100 RPM)
  • green (18:1, 200 RPM, the default)
  • blue (6:1, 600 RPM).
This must match the cartridge physically installed in the drivetrain’s motors.
Screenshot of the Drivetrain Settings screen, with the Gear Cartridge options highlighted, showing red, green, and blue cartridge options.
Additional Settings for No Sensor#
If you selected No Sensor, two additional settings will also appear:
  • Track Width — The distance between the left and right wheels.
  • Wheel Base — The distance between the front and back wheels.
These measurements help the Drivetrain estimate its movement without an Inertial, GPS, or Gyro Sensor to measure it directly.
Screenshot of the Drivetrain Settings screen for a Drivetrain with No Sensor, showing the additional Track Width and Wheel Base options.
Finish Adding the Drivetrain#
Select Done to add the Drivetrain to your robot.
Screenshot of the Drivetrain Settings screen, with the Done button highlighted.
View the Drivetrain in Your Devices List#
The Drivetrain will now appear in your list of devices, and the Drivetrain category and blocks will be added to your toolbox.
Screenshot of the Devices tab, showing Drivetrain in the list of devices with its left, right, and Inertial ports.
