Using Comment Blocks#
This tutorial covers how to use Comment blocks in VEXcode GO. By the end, you’ll know why and how to use comments to document a project.
Comment blocks let you add notes directly into your stack of blocks, found in the Logic - Comments category in the toolbox. They don’t affect how your project runs — they’re only there to help you and others understand it.
when started :: hat events
[comment]
Programmers use comments to organize their code and make it easier to read and understand, both for themselves coming back to a project later and for others working on it. A single block’s name only describes that one block, but a comment can describe the behavior of an entire section of blocks at once — so you can understand what a stack of blocks does at a glance, without reading through each individual block.
For example, this project drives forward until it bumps into something, then backs away. As written, understanding that takes reading through every block.
drive [forward v]
wait until <[bumper v] pressed? :: custom-led>
stop driving
drive [reverse v] for (100) [mm v] ▶
Adding a comment above each section describes its behavior, making the project easier to understand at a glance.
[Drive forward until something is in the way.]
drive [forward v]
[Back away from the object.]
stop driving
After connecting your robot to VEXcode, select Start to run the project. The robot will drive forward, stop and back away once it bumps into something.
