Skip to main content
Ctrl+K
< Back to Platform Select
  • VEX GO
  • VEX GO API Reference
  • VEXcode Tutorials
  • Navigating VEXcode
English
  • Español
  • 简体中文
  • Ελληνικά
  • VEXcode Robotics Logo
Section Navigation
  • Blocks
  • Python
  • VEXcode Tutorials
    • Moving Your Robot
    • Turning Your Robot
    • Connecting to Your Robot
    • Configuring Your Robot Build
    • Moving and Removing Blocks
    • Starting a Project
    • Naming and Saving Your Project
    • Opening a Project
    • Understanding the Drive Tab
    • Using Comment Blocks
    • Understanding Sequences
    • Creating a My Block
    • Stepping Through Blocks
    • Using Examples
    • Using Help
    • Wait Until True
    • Detecting Colors
    • Detecting Objects
    • Using the Electromagnet
    • Using the LED Bumper
Platform Navigation
Navigating VEXcode#
Navigating VEXcode
This tutorial covers the basics of the VEXcode GO workspace, including the toolbar, run controls, tabs, and block categories. By the end, you’ll know what each part of the screen does.
The platform icon in the top-left shows the VEX platform your project is set up for.
Screenshot of the VEXcode GO toolbar, with the platform icon highlighted.
Select the globe icon to change the display language.
Screenshot of the VEXcode GO toolbar, with the language switcher icon highlighted.
Select File to create a new project, open an existing or example project, save your project, or view VEXcode info such as the version number and privacy policy.
Screenshot of the VEXcode GO toolbar, with the File menu highlighted.
Select Tools to access keyboard shortcuts, install firmware, download drivers, change the Blockly color theme, get a link to the API Reference, adjust VEXcode settings, or toggle expanding the Logic category.
Screenshot of the VEXcode GO toolbar, with the Tools menu highlighted.
Select View to add tabs, reset your tab layout, or zoom in, out, or reset the zoom level in the toolbox.
Screenshot of the VEXcode GO toolbar, with the View menu highlighted.
Select Tutorials to open the tutorial list in the Help tab.
Screenshot of the VEXcode GO toolbar, with the Tutorials button highlighted.
Select Builds to go to builds.vex.com for build instructions for the VEX GO Kit.
Screenshot of the VEXcode GO toolbar, with the Builds button highlighted.
Select Undo or Redo to step backward or forward through your recent changes.
Screenshot of the VEXcode GO toolbar, with the Undo and Redo buttons highlighted.
Your project’s name is shown here. Select it to rename your project and save it to your computer. A warning icon appears if you have not saved your project and autosave is not available.
Screenshot of the VEXcode GO toolbar, with the project name highlighted.
Select Connect to connect VEXcode to your VEX GO Brain.
Screenshot of the VEXcode GO toolbar, with the Connect button highlighted.
Select Start to run your project, Step to run it one block at a time, or Stop to stop it.
Screenshot of the VEXcode GO toolbar, with the Start, Step, and Stop buttons highlighted.
Select Share to download a PDF of your project to share, or Feedback to send feedback to VEX.
Screenshot of the VEXcode GO toolbar, with the Share and Feedback buttons highlighted.
The Devices and Help tabs appear here by default at the start of a project. Additional tabs can be added using the View menu.
Screenshot of the VEXcode GO window, with the Devices and Help tabs highlighted.
Select Code or Drive to choose how you want to control your robot — by coding it, or driving it yourself. Drive lets you drive a connected robot directly, choose which devices are connected, pick a drive mode, and see real-time data about your robot as you drive.
Screenshot of the VEXcode GO window, with the Code and Drive mode tabs highlighted.
The colored icons on the left side of the screen are the categories, helping you navigate through all the blocks you can use in the project. As you add devices to the project, more categories will appear here.
Screenshot of the VEXcode GO window, with the block categories on the left side of the screen highlighted.
Selecting a category scrolls the toolbox to that section, so you can drag its blocks into your project.
Screenshot of the VEXcode GO window, with the toolbox highlighted, showing the Inertial category's blocks.
The rest of the screen is your workspace, where you build your project by connecting blocks together. Use the zoom controls in the corner to zoom in, out, or reset the view.
Screenshot of the VEXcode GO window, with the workspace highlighted, showing a when started block and the zoom controls.
previous
VEXcode Tutorials
next
Moving Your Robot
VEX and VEX Robotics are trademarks or service marks of Innovation First, Inc. Copyright ©2026. All Rights Reserved. VEX Robotics, Inc. is a subsidiary of Innovation First International, Inc. All other product names / marks of others are the property of their respective owners. Patents and / or Patents Pending - innovationfirst.com/patents
Site Privacy Policy / Site Terms of Use / Cookie Policy / Software Privacy Policy
Visit the VEX Robotics Facebook Page Visit the VEX Robotics Twitter Page Visit the VEX Robotics Instagram Page Visit the VEX Robotics YouTube Page
VEX API Feedback Form
We value your feedback! Use this form to share suggestions, compliments, or report errors with the VEX API. Your input helps us enhance the VEX API documentation.
If you are experiencing technical issues or require customer support, please visit support.vex.com.
  • Send Happy Feedback
  • Send Sad Feedback
Note: the current URL will be shared with your message
By including your email address, you agree that VEX may send you email emails if we have questions about your feedback.
Privacy Policy >
Please provide your feedback. Feedback submitted successfully!
VEX IQ (1st gen)
VEX IQ (2nd gen)
