Connecting with a Wired Connection (Windows)#
Follow these simple steps to connect your VEX AIR Drone Controller to your computer with a USB-C cable.
Turn on the controller#
Turn on the controller by holding down the power button and releasing when it begins flashing white. The video below shows the power button being pressed until it starts flashing white. The button continues flashing as the screen turns on, and turns green when the controller is ready for use.
Plug in the cable#
Use a USB-C cable to connect your controller to your computer.
Select the Controller icon in the top-right corner#
Follow the device prompts#
Pick the right connection option#
Select the option with Communications Port.
Finalize your connection#
You are connected#
The Controller icon in the upper right corner of VEXcode AIR will now appear green.
